Author Topic: Max Res For a TV?  (Read 2329 times)
lettuce
  • Make It So!
Max Res For a TV?
« on: June 27, 2006, 05:38:38 am »
Whats the maxium resolution a TV set can go up to, is it 800x600, and is this the best res to run windows in, any options under windows to get the display looking better when using  a Tv?
Gaston77
  • Last login:February 21, 2011, 06:53:44 am
  • MDF nearly killed me!
Re: Max Res For a TV?
« Reply #1 on: June 27, 2006, 07:04:48 am »
I have used windows on a tv with 1024 * 720 for a looong time with no problems at all. Don't know if this decreases the longevity of the Tv though...
this is my........BOOMstick!
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #2 on: June 27, 2006, 11:43:22 am »
To get the best picture with TV-out, use a desktop resolution of 720x576 (PAL) or 640x480 (NTSC). All other resolutions will be scaled/cropped by the graphics card to one of these anyway.
  • Last login:Yesterday at 05:27:25 pm
« Reply #3 on: June 27, 2006, 06:07:53 pm »
This is a good question!
My video cards lowest setting is 800x600 and the TV crops both sides just a bit. I'll look and see if I can get a bit lower of a setting.
lettuce
  • Make It So!
« Reply #4 on: June 27, 2006, 07:29:33 pm »
Well i shall be using my TV via th Scart Socket, and not TV out on the card, not sure if this makes a differences
TOK
  • The Game Always Wins
« Reply #5 on: June 27, 2006, 09:12:08 pm »
You can see the lower resolutions by right clicking on the desktop, clicking the Advanced tab in display properties, select the Adapter tab and then click the List All Modes button at the bottom left.
« Reply #6 on: June 27, 2006, 09:40:17 pm »
Awesome...
I didn't know that did that. It does a better job at that res. I can see everything good. Thanks!
MonMotha
« Reply #7 on: June 28, 2006, 01:21:14 am »
In NTSC land, 480 visible lines is the norm (525 total, the rest blanked or used for sync time).  In PAL land, that numer is higher (576 visible and 625 total IIRC, but I'm in NTSC land so look that up).  NTSC spec would call for 59.94Hz interlaced, PAL would use 50Hz.  If you have an HDTV or EDTV, it'll probably have a scaler that will enable it to accept other modes, as well.  Note that the horizontal resolution is not specified as it is defined by the bandwidth of the signal - 720 is usually taken as the most you'll get out of any TV system.  640x480 could be useful as it gives square pixels on a 4:3 TV.
TV out on a video card will adjust everything for the TV standard you specify (scaling, converting framerates, and interlacing as needed).  Using the RGB/VGA output on a SCART input won't do that, but your TV seems to be taking either mode fine: it may have a scaler or it synced up at PAL timings for 800x600 and NTSC timings (apparently most european TVs are dual format?) for 640x480.  I know that by default, Windows won't let you use those odd resolutions, but there are applications that will (Powerstip seems popular) or you can take my solution and run Linux :)
The TV cropping off the edges is normal and is known as overscan.  You can compensate for this somewhat on the horizontal sides by increasing the "porches" on the signal (these are the blanked, non-active portions of each scanline) to make the picture narrower.  Vertically, there isn't much you can do other than blank some of the lines (thereby decreasing the number of used/visible scanlines) unless your TV has a scaler.  You may also be able to get away with adding a few scanlines into the signal (blanked and unusable) to get rid of the overscan, but this can make fixed frequency monitors (like most TVs) very unhappy (and can actually break them).  Some TVs may allow you to adjust the overscan in a similar manner to a PC monitor.  Apparently european TVs are better in this regard (providing tons of user adjustments) than USA TVs, but I am not experienced with them.
