Author Topic: CP Artwork input requested - Last Pass  (Read 1659 times)
theCoder
« on: June 27, 2006, 04:34:02 am »
Last (??) pass.  Bring on the rocks & tomato's.  I can take it.  It is at the bottom of the thread at:
http://forum.arcadecontrols.com/index.php?topic=53486.80
Thanks for your input.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Re: CP Artwork input requested
« Reply #1 on: June 27, 2006, 10:05:40 am »
The thing that really strikes me about the art is that it's all over the place - there's no anchor, nothing that holds it together. The one common element that I've seen in most of the popular CPO's on this board is the use of some graphic element (often a grid, though I'm not reccomending that for yours) to help tie the various elements together.
With that in mind, suppose you took that blue "wave" that is a common element here and elsewhere on your cabinet and make that the base. Then select a complimentary color and use that to create the overlaying elements that you're using in your current design to hold the buttons, etc.
If I get more time, I'll try to show you what I mean.
Make your cabinet look its best with custom art from
Gamecreature!
