Author Topic: Two Mala questions  (Read 4829 times)
mccoy178
  • Go Bucks!
Two Mala questions
« on: June 27, 2006, 01:02:29 am »
I didn't see a definitive answer in the wiki or through searching.  Does mala work with the LEDWiz?  I presume it doesn't, but I want to find out.  Also, does it have pre and post emulator command lines?  I use a betabrite on my machine that currently uses mamewah to call the file necessary to display the proper name.  Also, I am looking for the command lines for Johhny5 and the like.
loadman
    • MaLa
Re: Two Mala questions
« Reply #1 on: June 27, 2006, 01:39:57 am »
Refer Website note: http://mala.arcadezentrum.com/help.html#faq8
yes......  Refer Website note: http://mala.arcadezentrum.com/clplaceholder.html
« Last Edit: June 27, 2006, 01:58:26 am by loadman »
mccoy178
  • Go Bucks!
« Reply #2 on: June 27, 2006, 02:08:31 am »
Thank you for the link.  The answer is no, mala does not support LEDWiz internally.   :badmood: I think J5 in the future will handle this.   :cheers:
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #3 on: June 27, 2006, 03:21:02 am »
There is no implicit support for the LEDWiz. I don't know how it works to 'program' the LEDWiz, but maybe it is possible with the encoder programming or the pre/post emulator commands. With the encoder programming you can easily execute/send files on a per game basis. If no config for a game is found MaLa will use the emulator config instead.
