Author Topic: Unidentified arcade monitor...anybody recognize this one??? Fixed!!!...sorta...  (Read 2912 times)
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Me and a buddy scored a cab with this 27" in it.  The guy we got if from gave up on his MAME project so we got the cab, parts, and this monitor.
Can anybody identify it by looking at it???
I have yet to find any markings on the neckboard or chassis as to its manufacturer or model.  I have not taken the chassis off to look underneath it.  That may be my next move if no one can ID it.  The tube has a Philips label with  A66EAK252X44 on it.
The guy said it was working for a while, then it just quit.  I plugged it in and put a signal through it, all I got was a blue horizontal line across the middle of the screen.  I found a cracked V-size pot on the little adjustment board but that's it.  I would like to shotgun that pot but I have no idea what value it might be.
Any input would be apreciated...
« Last Edit: July 06, 2006, 06:26:21 am by ArtMAME »
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: Unidentified arcade monitor...anybody recognize this one???
« Reply #1 on: June 24, 2006, 11:06:38 pm »
WEIRD beastie.
On the back of the tube, those first few numbers: A66 regards the size of the tube.  the number denotes the size in centimeters.  63 would be a 25", 68 would be 27".  So...a 26" monitor?
Can you get a closer pic of the chassis?
ArtMAME
    • Art's Arcade Lab
« Reply #2 on: June 25, 2006, 10:04:56 am »
Yes...WIERD indeed.
Here are some more pics.
grantspain
« Reply #3 on: June 25, 2006, 10:37:14 am »
is there a name on the component side of the neck card
ArtMAME
    • Art's Arcade Lab
« Reply #4 on: June 25, 2006, 11:19:18 am »
None that I can see...sorry... :badmood:
ArtMAME
    • Art's Arcade Lab
I messed with the monitor a bit last night... I removed the broken V-size pot and replaced it with the V-center pot just to see if I could at least get the monitor working.
It worked!!!  :applaud:
 I measured the pot before I put it in there, looks like it is a 10K pot.
It has a VGA connection so I just plugged it into a spare PC.  Looks like the monitor will do PC resolution of 640x480, tried 800x600 but went out of sync.
All the other adjustments worked fine and the quality of the picture is great.  Now I just have to find a 10K pot for the V-Center.  Still don't know what brand the monitor is ???
Kevin Mullins
    • Me on Myspace
What all does it have as far as writing on the edge of the chassis, especially near the power input?
(left side on this pic)
Might be able to cross some P/N type numbers.
Ken Layton
  • Guru
  • Technician
Could this be a Pentranic or Makvision monitor? This one does not look like any monitor I have seen. Perhaps Jomac in Australia could identify it.
Akide
  • Last login:July 16, 2021, 05:37:54 am
Hi, i have a monitor very similar and with the same number A66EAK252X44 !!!
My monitor is a SuperSquare made by Monivision!
I have some problem with resolutions! Do you have some driver for it?
Make me an answer please!
ArtMAME
    • Art's Arcade Lab
I believe my monitor only displays 640x480 resolution.
What kind of problems are you having with the resolutions?
I have used 640x480 resolution and it works.
But 800x600 does not work on mine...
I have tried lower resolutions (15KHz) using a tweaked ATI Radeon card and Powerstrip but they do not work either...
The monitor was given to me, so I do not have drivers for it. Sorry...
Akide
My monitor work fine with 640x480 (60 Hz -75Hz ) 800x600 (60Hz) 1088x612 (60 Hz) but with 1024x768 it is very tightened and i can't regulate! Can you help me?
tranq
  • - Banned -
  • Last login:January 11, 2007, 05:04:35 pm
  • - Banned -
I like that bracket/housing.  Be nice to have that on other monitors, to simplify maneuvering, as well as, mounting.
« Last Edit: January 03, 2007, 07:49:43 pm by tranq »
