Author Topic: Ultimarc's PSX adapter issue  (Read 1444 times)
kaizor
  • Last login:August 26, 2006, 04:56:03 am
« on: June 19, 2006, 01:56:46 am »
Hello,
I'm having issues with the adapter.  It seems when I have a keyboard through the pass connector it pauses on every buttom press.  It gives me an error saying that the controllers are not connected.
When I remove the keyboard from the passthrough slot, everything works for the most part, exec pt when certain buttons are pressed simultaneously giving me the same error (about 6+ buttons seems to duplicated the error).  I tried just plugging in a keyboard to the adapter without the IPAC and everything works perfect, with almost all keys pressed.  I'm really at a lost to how to fix this.
Other info:
IPAC4 board.  All keys are defaulted except Players 3 and 4 , switches 5-8 which I had to assign a key to because the defaults are blank.
The ps2 game I was testing was "Marvel vs Capcom 2" which is a capcom fighting game.
Any help on this problem would be greatly appreciated.
zakk23
  • Last login:July 21, 2006, 03:49:31 pm
Re: Ultimarc's PSX adapter issue
« Reply #1 on: June 19, 2006, 11:57:25 pm »
Does it do this with other games?
I think some of the Capcom games just do not like the ultimarc adapter. Third Strike freaks out with it too.
kaizor
« Reply #2 on: June 21, 2006, 01:15:40 pm »
Yep almost all capcom games.  I haven't tested it with Tekken 5 or Guilty GearXX Reload yet as I don't have the copy.  But all other non-fighting games seems just fine.
Contacted Andy, he's sending me two chips at that add on to the adapter that should fix it.  I'll report back once I get a hold of these and run some tests.
