Author Topic: Suggestion on CP layout  (Read 1773 times)
tore-
  • Last login:June 11, 2014, 06:18:33 am
« on: June 18, 2006, 06:09:47 pm »
Im currently redesigning my CP, but im having problems with finding the correct layout.
Im currently using 2x Mag-sticks from ultimarc (http://www.ultimarc.com/controldiags.html), 2xtrackballs from ultimarc with mounting plate, and 6x buttons for each player, plus 3x buttons for each player to function for the trackball.
Max size of the CP is 26.5/13 inches.
As you can se, im limited with space.
Thanks alot.
DaveMMR
Re: Suggestion on CP layout
« Reply #1 on: June 18, 2006, 09:48:35 pm »
The "swapping panels" didn't work out for you?
tore-
« Reply #2 on: June 19, 2006, 02:40:02 am »
Swapping panels is to much of a hassle. I would rather have the trackballs with the sticks at the same time.
Maybe I'll have to print ut some measurements and just build the CP, and then try some different versions of placement.
