Author Topic: Plexiglass too big. Few tools, less experience. Options?  (Read 10083 times)
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« on: June 16, 2006, 08:14:01 pm »
The plexiglas for my marquee is just a little bit too wide for my cabinet. I have no experience with trimming plexiglas and few tools available - what are my options to trim 1/8" off of it so it will fit?
Make your cabinet look its best with custom art from
Gamecreature!
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
Re: Plexiglass too big. Few tools, less experience. Options?
« Reply #1 on: June 16, 2006, 09:31:49 pm »
Did you buy the plexiglass from mamemarquees along with your marquee?  Just curious because my plexi is slightly too big as well.
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« Reply #2 on: June 16, 2006, 10:05:42 pm »
Home depot sells handheld plexiglass cutters i think there around $10.00 :)
gamecreature
    • Gamecreature
« Reply #3 on: June 16, 2006, 11:02:40 pm »
As a matter of fact, yes.
Gamecreature!
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 17, 2006, 12:12:20 am »
List some tools that you do have available....
Box-knife?
Sander?
Circular saw?
Clamps?
This will help to give you different ideas....
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #5 on: June 17, 2006, 12:15:05 am »
If he's trying to trim off 1/8 of an inch, scoring and snapping won't work at all...
You could probably grab a sanding block and some heavy sandpaper and start chopping away at it. You could also try a spokeshave...not sure how they work with plexi though. Anybody have any experience with a spokeshave and plexi?
I had to beat them to death with their own shoes...
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #6 on: June 17, 2006, 12:47:14 am »
For trimming off such a small amount, nothing beats a router. You might try either a dremel with router attachment or a laminate trimmer (both cheaper than a router). Like JonnyBoy said, you can't really snap off such a small piece.
Personally though I think it rather odd that MameMarquees provided you with plexi cut to the wrong width. I thought the entire point of buying from them was that you didn
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #7 on: June 17, 2006, 02:02:58 am »
I ordered my monitor plexi about 1/16th to big on purpose that way I would be ensured it wouldn't be to small. I just made a 120 grit sandpaper block and took my time with it! Anyway it takes a while, but it worked sweet! This way you don't have to worry about taking too much off. Make sure that you protect the plexi with some tape or something for when you slip while sanding :)
My old user name was marlborroman13, but I kicked the habit many years ago!
  • Last login:November 30, 2025, 12:59:41 am
« Reply #8 on: June 17, 2006, 03:52:08 am »
I agree with the sanding block solution - your case with limited tools. I've used my belt sander and it works quick. 1/8 of an in off the width would take a bit a time, but totally do-able. A router with a flush trim bit works great too. I find rigging up the jig and setting up the router take the longest bit of time. The actual trimming is measured in seconds, while the setup is minutes.
Seriously though... mounting the marquee is so rewarding. It's one of the moments when I feel like I can see the light at the end of the tunnel. What a bummer when you run into something like this.
gamecreature
    • Gamecreature
« Reply #9 on: June 17, 2006, 08:41:48 am »
I don't have a router  :( but I do have a sanding wheel for my drill. Might be worth a try?
Gamecreature!
gamecreature
    • Gamecreature
« Reply #10 on: June 17, 2006, 10:31:24 am »
Gamecreature!
« Reply #11 on: June 17, 2006, 11:14:01 am »
I would just use sandpaper and make a block (wrap it around something) and start working it down. I'd be afraid of losing control with the wheel, but I'm sure you have better control than I do.
tommy
« Reply #12 on: June 17, 2006, 05:41:44 pm »
Just sand it down with a good hand-held sander, no need to start cutting into it for an 1/8 inch.
Knievel
    • Knievel Kustoms
« Reply #13 on: June 18, 2006, 12:08:21 am »
Staple a coarse piece of sandpaper to your bench and then rub one end of the plexi back and forth over it until you get it down to the size you need.
Should make fairly quick work of the job and you won't risk scratching the plexi.
You might need to follow it up with a fine sandpaper.
rdagger
« Reply #14 on: June 18, 2006, 02:52:02 pm »
If you have access to a chopsaw, it works great for trimming small pieces of plexi and Lexan.  It is not very good for cutting because it wastes material and can splinter the plexi, but it will very quickly shave off 1/8" of material with an even line.
« Reply #15 on: June 18, 2006, 06:17:14 pm »
Really? What blade would you use - how many teeth?
My chopsaw is using a 24t blade that I primarily use to trim up 2x4's. I'm assuming you'd want smaller + more teeth to do that kind of finishing work?
All the same, plexi costs too much to put under that if you ask me. 1/8 inch ain't worth the potential disaster. I'd go the sand paper+hand sand route.
rdagger
« Reply #16 on: June 18, 2006, 08:38:59 pm »
I use a 10" 80 tooth thin kerf blade.  I've cut quite a bit of stuff besides wood with my saw such as aluminum, Lexan, UHMW, PVC, etc.  It is risky cutting acrylics and polycarbonate because the piece can shatter if they are not clamped and cut properly.  However, trimming is fast, easy and gives excellent results.  My cab has more pieces of Lexan than most.  Most of it was cut slightly larger than necessary with a box cutter and then trimmed with the sliding chop saw.
