Author Topic: Vertical Roll Issue  (Read 1277 times)
BigDuke6
  • Last login:January 16, 2007, 10:07:38 pm
  • Click where?
Vertical Roll Issue
« on: June 13, 2006, 09:30:43 pm »
Howdy all.
I am at my wits end with my monitor and wanted to try and see if anyone out there had any advice after searching through the forum for hours.
I have a SI-527DS-SY monitor, (Sharp Image Sony 27" Dual Scan) that has a vertical roll issue.
I am using the Ultimate Arcade card.  I finally got the split screens with black bar in the middle corrected.  I have a nice full screen now but cannot get it to stay put!  It will stay for a minute after MUCH fine tuning with the vetical POT, then it will slowly start to roll from top to bottom.
What do the monitor experts think?  Anyone see this monitor/issue before?
TIA
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: Vertical Roll Issue
« Reply #1 on: June 14, 2006, 01:24:49 pm »
Is that quite an old monitor? CGA/EGA/RGBHS?
Could be that the monitor is expecting bigger vertical syncs. The ArcadeVGA (I assume thats what you mean) I believe outputs 1V syncs (like most VGA cards) whereas some old monitors need/expect 5V syncs.
You can buy an adapter/booster (Ultimarc, who sell the ArcadeVGA, sell one I believe). But this may not be the reason. Check your settings in the driver options - some ATI (on which these are based) allow you to change the syncs to composite/positive/negative which may also help.
If it is an ArcadeVGA I would suggest emailing Ultimarc, who are both extremely knowledgable and very friendly.
BigDuke6
  • Click where?
« Reply #2 on: June 16, 2006, 09:41:10 pm »
Awesome.
Yeah I got it from Andy.  I will email and see what he thinks.
Thanks for the reply
cbcellman33
  • Last login:June 08, 2009, 06:21:59 pm
« Reply #3 on: June 21, 2006, 08:51:40 pm »
i had the same problem...make sure you are using both vertical and horizontal sync...
