Author Topic: Mala Screensaver Bug?  (Read 5449 times)
« on: June 13, 2006, 05:57:12 pm »
Well, I think I've confirmed it. When I used the Mala screen saver to pull pictures from the c:\mame\snap directory, the system has a hiccup like something else is running. When I use a windows screensaver, it's fine. Here is my setup:
Dell Dimension 1100
Celeron D 2.53ghz
19" Vertical monitor
Male RC5 set in Vertical orientation
I thought it was my system so I reformatted it. It worked fine, until after the screen saver kicked in. So, I powered it down and tried the windows screen saver - I left it on for a day. It worked without issue. Switched the screen saver to Mala and as soon as the screen saver kicked on - it would play a game for about 8-10 seconds and do a little skip (sound and motion).
Hope this helps. It's not a big deal really, I just switched it back to the windows screen saver.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Re: Mala Screensaver Bug?
« Reply #1 on: June 14, 2006, 07:46:51 am »
Yes, it was a bug. The screensaver was running in the background when activated.
loadman
    • MaLa
« Reply #2 on: June 14, 2006, 09:14:47 am »
...Ahh I have i similar problem but never attributed it to mala
:-)   :P
http://mala.arcadezentrum.com/wip.html
Thanks SWINDUS for actioning issues so quickly   ;)
« Last Edit: June 14, 2006, 07:54:25 pm by loadman »
