Author Topic: Alternative to Joy2Key?  (Read 7923 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« on: June 12, 2006, 05:15:18 pm »
Hey! Wow havnt been on here in almost 2-3years! But Im back into my Mame cabnet work and looking to update some things...So good to be back!
Anyway to my question which is pretty obvious...last I was here best option was Joy2Key for a Gamepad-Keyboard Emu...heard there is some other options now including on highly advanced Retail program...Could someone please enlighten me to the names of these other program?
gonzo90017
Re: Alternative to Joy2Key?
« Reply #1 on: June 14, 2006, 07:47:30 pm »
There's only a couple I know of. Total Game Control :Shareware, and Joykeys :freeware. But joy2key works better and is easier. Are you having trouble with it?
Syxx
  • Bling Bling
« Reply #2 on: June 15, 2006, 12:56:03 am »
Yes im trying to map something like say for instance on a PSX control as example X+[](square) = ESC and I cannot do multi button macros for some reason.
Lilwolf
« Reply #3 on: June 15, 2006, 08:11:40 am »
is this for mame?
because you can do all that IN mame with the original controls... and that way you don't have to run other software that might slow down your performance.
Syxx
  • Bling Bling
« Reply #4 on: June 15, 2006, 11:55:47 am »
Its for Mame, StepMania, SNES, NES Etc...So I basicly need a key combination to = ESC so I can exit but not have it be just 1 key on the pad so I dont accidetnly hit it and quit.
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: June 16, 2006, 06:32:46 pm »
I'm not too sure about how joy2key works, but perhaps you can write a small Autohotkey script. I'm not sure if it support multiple button presses, but it may do. Try the JoystickTest script and go from there.
gonzo90017
« Reply #6 on: June 17, 2006, 06:15:37 pm »
I'm also using some psx pads. I map esc to the Select button. It's kind of hard to hit that one accidentaly. For mame I use the Start buttons as both Coin and Start. Killing 2 birds with one stone. You can also use Alt+F4 to exit with most emulators.
