Author Topic: MAMEWAH - disable options  (Read 1414 times)
tm
  • Last login:July 14, 2006, 10:04:57 am
« on: June 10, 2006, 11:38:21 am »
can someone pls advise on how to disable the options on mamewah when keyboard button '2' is pressed - i want to disable the options to find game,music options etc.
tas
Re: MAMEWAH - disable options
« Reply #1 on: June 12, 2006, 07:54:49 am »
Use the menu lock shortcut...I forget what the default keys are but take a look in your ctrlr file (default.ini or mamewah.cfg depending on version) and it will say.
Or just edit mamewah.ini and set 'locked 1'.
tm
« Reply #2 on: June 12, 2006, 09:35:38 am »
done it - thanks for your help.
tas
