Author Topic: In game studdering in mame - is it something in my ini? Problem Solved!  (Read 1217 times)
  • Last login:February 04, 2026, 05:27:25 pm
I'm running a custom compile version of mame to remove the video error messages. I am now experiencing some sort of hiccup that occurs every 25-30 seconds in game. I copied Mala and Mame off my computer and formatted the computer. The computer is a 2.53mhz Celeron with 512 memory running XP Pro (no service packs). I copied Mame and Mala back to the computer and now I have this hiccup. I am running in vertical mode.
Do you see anything that could be causing anything like this in my ini? My next step will be to copy the official version back on and see if it is my version of mame. Thanks for looking.
### mame.ini ###
### Frontend Related ###
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
comment_directory       comments
cheat_file              cheat.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
# screen                <NULL> (not set)
cleanstretch            auto
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_gamma       1.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
# mngwrite              <NULL> (not set)
### Windows Direct3D 2D video options ###
zoom                    2
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows misc options ###
sleep                   1
rdtsc                   0
priority                0
### Windows sound options ###
audio_latency           1
# wavwrite              <NULL> (not set)
### Input device options ###
mouse                   0
joystick                0
lightgun                0
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           1
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
digital                 none
### Mame CORE video options ###
norotate                0
ror                     1
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
sound                   1
volume                  0
### Mame CORE misc options ###
validate                0
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# debugscript           <NULL> (not set)
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
oslog                   0
skip_gameinfo           0
bios                    default
# state                 <NULL> (not set)
autosave                0
### Configuration options ###
readconfig              1
verbose                 0
skip_warnings           1
skip_disclaimer         1
skip_gameinfo           1
« Last Edit: June 11, 2006, 12:27:02 am by leapinlew »
I'm building a couple of mame machines. On the second machine I loaded XP Pro SP2 and all seems to be fine. I took the original machine and reformatted it and this time used XP Pro with SP2 slipstreamed in. Works like it's supposed to.
It's a newer dell that came preloaded with SP2 to begin with. I did a format with a XP Pro disc that wasn't sp2.
It's all good.
