Author Topic: Cheap Air Conditioning  (Read 1016 times)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
Curls in the squat rack !?!?!
Havok
  • Trade Count: (+17)
Re: Cheap Air Conditioning
« Reply #1 on: June 06, 2006, 11:01:13 am »
And if you need cheap hot air - just listen to Mr C.
 :laugh2:
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #2 on: June 06, 2006, 02:04:18 pm »
That's a pretty cool idea.
I had this "room air conditioner" once.  It blew air over water (that was put in a resevoir) that was in a paper membrane.  It came out cold.
It said it only worked in rooms that were already air conditioned, it just lowered the temperature.  It worked great.
Now that I think of it, it's just a humidifier.
This device this guy built doesn't remove the humidity from the air when it cools it like a real A/c unit does through the condensation pump.  So if he's cooling the air, everything in his house should be damp, no?
Jacktucky
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #3 on: June 06, 2006, 05:22:56 pm »
Note he said cheap, not free.  You have to spend your time. ;)
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
crashwg
« Reply #4 on: June 06, 2006, 08:14:12 pm »
Just put something similar together at work for the "glove box" which is basically a box that we run argon/helium thru while welding tungsten.
It was just a heat exchanger from the autoparts store and a 120mm fan.
If you wanted to get fancier with the setup Edgedamage posted you could use a full sized radiator...  :P
Wow, I just had a pretty sweet idea.  The inlaws have a well that has a pretty decent runoff.  They could easily hook onto that, make a loop that goes into the house, thru a radiator or three setup at various points of the house with a fan behind em, then back out to wherever it is that the water goes now.  Heck they could hook a generater to the water output and power the fans with that!
« Last Edit: June 06, 2006, 08:20:56 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
