Author Topic: my ipac 4 not responding!  (Read 2389 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: June 05, 2006, 06:51:48 pm »
i'm sure this question was asked but i searched and no luck. so...
my i pac 4 worked before but when iplug it into my pc today NO RESPONDS!!! i replug it and restart it many times and no luck.
i'm using usb and this is new version of ipac 4 ( no jumper)
oh also i checked winpac and done test still no responds, made sure winpac are set to usb yes it is.
i even tried pluging my keyboard into passthu but that keyboard doesn't respond. i restart my ocmp to be sure but still no.
i even checked to be sure the ground wire are tight in the stocket yes it is.
« Last Edit: June 05, 2006, 06:55:46 pm by bossyman15 »
My website: www.bossyman15.com Lots of arcade pictures inside!
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
Re: my ipac 4 not responding!
« Reply #1 on: June 06, 2006, 12:21:00 pm »
Check the Ipac self-test LEDs on the board itself.  If it's anything like mine, the P3/4 LED is lighting as normal, but the P1/2 isn't.  If that's the case, there's a wiring problem somewhere on your CP.  I think mine turned out to be somewhere along the grounding lines I had.  Couldn't ever figure out where, though.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
bossyman15
« Reply #2 on: June 07, 2006, 12:16:33 am »
Well once again I forgot to update my current status...
Turns out I just had to plug the usb into different slot. Seems that I would have to do that every time I unplug my ipac4
cdbrown
  • Bowowow
« Reply #3 on: June 07, 2006, 08:06:04 am »
So was that usb slot not working at all or just with the ipac?  Curious to know why using the other USB slot worked.
bossyman15
« Reply #4 on: June 08, 2006, 04:22:20 am »
i don't know why. my computer are weird. everything i own are weird i dunno why. i must be cursed.
