Author Topic: Need help installing SVGAlib for use with AdvanceMAME on Redhat FC5  (Read 955 times)
displacedtexan
  • Last login:August 20, 2007, 11:13:38 pm
OK all the Linux gurus out there...
I am trying to install Advancemame on my newly built cocktail cab so that I can get games with different resolutions to work correctly.
I installed FC5, updated it, installed SDL (via yum), installed SVGAlib (from RPM via yum svgalib.i386 0:1.9.24-2.fc5), and installed advancemame (from source).  Everything works, but I am pretty sure Advancemame is using the SDL drivers.
I tried putting the following in my advmame.rc file:
device_video svgalib
and I get this:
Invalid argument 'svgalib' for option 'device_video'
Valid values are:
auto Automatic detection
fb Frame Buffer video
sdl SDL video
none No video
Error loading the video configuration.
I recompiled and re-installed advancemame and still get the same thing.
I have also tried adding:
alias char-major-209 svgalib_helper
to my /etc/modprobe.conf
and still doesn't work
Any ideas what's going on?  I think I would probably have problems installing svgalib from source on Redhat, but that may be what I need to do...
Anybody else have any ideas that may help me!!
Thanks!!
displacedtexan
Re: Need help installing SVGAlib for use with AdvanceMAME on Redhat FC5
« Reply #1 on: June 03, 2006, 05:10:06 pm »
I have made a few baby steps forward... I installed svgalib-devel and recompiled advancemame.  Now I get this when running advancemame:
Unable to initialize the video driver. The errors are:
svgalib: Unsupported without the svgalib library.
What linux distributions have people used to successfully install advancemame using svgalib?
Thanks!!
