Author Topic: How do I use P360s with a Dreamcast?  (Read 1158 times)
markrvp
  • NFL Expert
« on: May 31, 2006, 12:48:31 pm »
I've got a cabinet with a Sega Dreamcast in it and two hacked gamepads.  I would like to use two P360 joysticks.  I can get 5v from a switching power supply, but the ground wire needs to come from the Dreamcast, right?  How would I hook this up?
BTW, I know I can get 5v from the gamepad, but I am interested in how to wire power from an external power supply.
« Last Edit: May 31, 2006, 01:02:18 pm by markrvp »
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
Re: How do I use P360s with a Dreamcast?
« Reply #1 on: May 31, 2006, 02:38:40 pm »
What kind of power supply is it? All you really need is just a wire coming from the RED 5V line from the power supply to go into the 5V screw terminal on the P360. You don't need a ground for the PS as well. The ground will be from the game pad itself.
The way I have my p360's wired up is I have a long wire from the power supply with a male Quick Disconnect on the end, and then I have a wire from each of the p360's that terminate into a single female quick disconnect. Plug that in, and you are good to go!
markrvp
  • NFL Expert
« Reply #2 on: May 31, 2006, 02:44:10 pm »
It would be a stand-alone Happ switching power supply.
Hiub1
« Reply #3 on: May 31, 2006, 02:56:04 pm »
Just run a lead from the +5V terminal to something like what I described earlier and you should be good to go.
