Author Topic: Another resolution issue. avga and WG 7000 series.  (Read 2020 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: May 24, 2006, 09:34:58 pm »
Anyone running a wells gardner with an arcade vga wanna send me your mame .ini and you .ini folder? I ran the mame res tool from minwah , then I tried the one from mr. benson with the little galaga res ship for an icon (avres)  and I cannot get stuff to fit. If I get the horizontal games to fit the verts like pacman and mspac and galaga are to big. If I adjust the resolutions to make them fit the horizontal games are smushed and I have to adjust the vert size to expand to the correct size. does anyone have a tool that will make a list of .ini's that can take this into account? I set my windows res and frontend res to 640x288 and that looks great but it almost fits better at 640x480. either of the 2 will do. this is just the last step to finishing this cab. Must have games that fit!!
thx
-d88
« Last Edit: May 26, 2006, 07:24:47 am by delta88 »
delta88
Re: Another resolution issue. avga and WG 7000 series.
« Reply #1 on: May 26, 2006, 10:03:57 pm »
anything? I'm dying over here. Last thing to set up to finish cab ;)
thx
 d88
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #2 on: May 26, 2006, 11:14:50 pm »
The mame res tool should do it for you?  You can test out the resolutions before you make the ini file.   Sounds  like it is not making the ini files or it is not using them?  Is the monitor 15khz only?
D-
  Scratch built upright MAME Cab
delta88
« Reply #3 on: May 26, 2006, 11:58:57 pm »
its aplain jane  arcade monitor. still in its mortal kombat housing ;)
I was using the res tool and had all of the horizontal games cool but then I was working on the pacman/galaga games and could not get any of the resolutions to get the game to fit. soI then tried the avres tool and that got the verts to ll fit but now the horizontals are squished.. Im sure someone with a wellsgardner style monitor has to be using a similar saet of ini's..
thx
delta88
« Reply #4 on: May 28, 2006, 08:42:18 am »
further messin and reasing. Is there a ini or cfg file I point the res toll unto that will automatically adjust  all of the ini's? cuz it still kina sounds like you have  to go through all of the gamesand adjust them. Granted the tol can generate inis for multiple groups of games but I had tried every option in the drop downs for galaga and not a  single one would fit. Ihad even adjusted the screen size to be sure it just was not an adjustment issue on the monitors part.
thx
d88
