Author Topic: Looking for vertical frontend  (Read 1545 times)
madk
  • Last login:March 28, 2017, 04:59:49 pm
  • I actually am a llama!!
    • Digital Something
« on: May 20, 2006, 12:40:17 pm »
I'm nearing completion on my old school cab and am starting to round up and config my software.  I'm looking for a frontend that works good for vertical monitors.  I'm using my ATI cards software to rotate the picture within windows xp.
Any suggestions?  Maybe I'll have to start writing my own.
Matt
Matt (mad-k)
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
Re: Looking for vertical frontend
« Reply #1 on: May 20, 2006, 02:39:57 pm »
the Frontend section of the wiki displays which frontends will work for vertical orientations. Take a look. If you are using rotation software with the video card, you may be able to use other frontends as well, that do not support it natively.
loadman
  • Last login:Today at 07:18:10 pm
    • MaLa
« Reply #2 on: May 20, 2006, 07:46:15 pm »
...Keep in mind there are some video cards that don't work well with mame with windows being rotated. I think it has something to do with the windows rotation software and mame hardware stretching trying to access DirectDraw at the same time.
You may be fine ..But If you have problems with some games (as I and others have) I recommend that you don't rotate windows and use a FE that can be orientated vertically and just set the FE to launch on start-up.
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« Reply #3 on: May 22, 2006, 11:15:14 am »
gameex its so far the best one in supporting vertical orientation.
And that's just my thought
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #4 on: May 22, 2006, 12:06:37 pm »
AtomicFE supports vertical screen too.
Quarterhorse
  • Last login:September 07, 2007, 01:25:17 pm
  • She tried grabbing Chuck's wheel -- ONCE
« Reply #5 on: May 22, 2006, 12:09:08 pm »
I've been very happy with MALA as my vertical fronend.  Easy to set up and quite a few tools to customize it.
Denverlatino
« Reply #6 on: May 22, 2006, 12:53:01 pm »
how do you filter games for vertical mode only?
kind of i like mala too, easy too use....fast good fe too , and free
« Last Edit: May 22, 2006, 02:16:31 pm by Denverlatino »
... Banned ...
