Author Topic: what resolution should artwork be to print out clear  (Read 3945 times)
Anakin
  • Last login:May 22, 2008, 02:30:15 pm
« on: May 20, 2006, 08:25:01 am »
I know 300 dpi is good but what about the resolution?
GoPodular.com
  • Last login:April 23, 2008, 10:09:55 pm
    • GOPODULAR!
Re: what resolution should artwork be to print out clear
« Reply #1 on: May 20, 2006, 10:19:36 pm »
That is the resolution.  dpi= "dots per inch".
  • Last login:November 30, 2025, 12:59:41 am
« Reply #2 on: May 20, 2006, 10:25:11 pm »
Resolution and DPI don't really have much to do with each other. Since you can fit 1"dot per inch" on a 8.5 x 11inch sheet or you can fit 10 billion dpi on the same sheet.
Resolution commonly means size - like 800x600
DPI means - dots per inch. The more dots - the more quality.
To answer your question - I did my last cp at 300dpi and it was fine. I would probably do 600dpi on the next one - just cause I can...
Anakin
« Reply #4 on: May 20, 2006, 11:14:47 pm »
I'm using this image below on my control panel and when i change it to 300dpi i notice a lot of fuzziness on it when i zoom in.  I'm trying to find out how this image would look like when i stretch it to 42x16 inches..
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
« Reply #5 on: May 20, 2006, 11:16:44 pm »
unless its vector you are going to get pixelation  :'(
« Reply #6 on: May 20, 2006, 11:42:54 pm »
True true
Anakin
« Reply #7 on: May 20, 2006, 11:59:21 pm »
well guess i'm out of luck  :( this is what i wanted for my control panel.  unfortunately for me, i have no clue how to do vectore
« Last Edit: May 21, 2006, 12:01:58 am by Anakin »
Anakin
« Reply #8 on: May 21, 2006, 12:03:12 am »
my CP
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #9 on: May 21, 2006, 12:46:53 am »
Also remember up-sampling does no good.
If you start with a 72dpi image and you change it to 300 dpi you just added more dots you didn't make the image any better.
Capthowdy
  • Last login:April 13, 2015, 03:33:18 pm
« Reply #10 on: May 21, 2006, 03:36:55 am »
my CP
ahh...i see the problem.  how's this??
ya gotta give them something to fight over!!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #11 on: May 21, 2006, 11:27:23 am »
Hit the Artwork forum and offer someone a few bucks to vectorize it for ya.
NO MORE!!
GoPodular.com
    • GOPODULAR!
« Reply #12 on: May 21, 2006, 03:08:05 pm »
DPI:
http://en.wikipedia.org/wiki/Dpi
"Dots per inch (DPI) is a measure of printing resolution..."  ;)
You can make any image smaller, but you have work ahead of you to make it bigger.  Either you fix it all pixel by pixel, or you vectorize it and then let it redraw itself.  Sometimes you can scan it at a high DPI, but I've seen mixed results doing it like that.  If you can use Paint Shop or Photoshop "normally", vectoring an image isn't out of your grasp.  It's just adjustable shapes rather then pixels.  When you blow up a vector image, it just recalculates itself and automagically gets rid of the jagged edges.
PoDunkMoFo
    • Visual Horizons
« Reply #13 on: May 21, 2006, 11:48:25 pm »
DPI:
Actually it doesn't get rid of the jagged edges because once you vectorize something there are no jagged edges.  Think of it as going from a dot by dot description of the image (bitmap) to a mathematical geometric description of the image (vector).
