Author Topic: PSUs?  (Read 1091 times)
sasuke_kun12
  • Last login:March 10, 2009, 09:05:13 pm
  • Its been to long... I'm never leaving this place!
PSUs?
« on: May 20, 2006, 03:38:13 am »
just got a quick one.
is it alright if i grab a psu for a p2 then use it for an amd athlon mobo?
 :troll:
Why are all the good, cheap lowboys in brisbane?
SirPeale
  • Green Mountain Man
Re: PSUs?
« Reply #1 on: May 20, 2006, 07:24:15 am »
Only if you want it to slowly die.
The power requirements of an Athlon are much more than a Pentium II.
It'll work for a while, but the load draw will kill the PS in short order.
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
Re: PSUs?
« Reply #2 on: May 20, 2006, 08:45:47 am »
Sure.
Just get one that will meet all the requirements of the newer system that you are putting together.  The rated wattage and kinds/amounts of connectors required depends on the hardware you select, how many devices you are powering, the tasks you will be doing, etc etc.
Things to consider - the p2 will probably need the standard 20 pin mobo connector; the new system may require additonal pins (depending on what you decide on).  You may want to find a power supply that has the 20 pin and additonal pins separate (or detachable from the 20 pins).  If your new system will have sata hard drives, get a psu with those connectors as well; same goes for the Video card power connectors  (if required - SLI, etc).
If you get one with all the connectors you will need later, it will save the trouble of finding adaptors, etc.
