Author Topic: Adhesive Remover  (Read 1741 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
Adhesive Remover
« on: May 19, 2006, 11:01:59 pm »
I was given a 2'x2' piece of plexi from a friend.  The problem is that there was apparently a piece of duct tape alaong the bottom for a while which was removed.  So there is adhesive residue as well as the strands left along with the bottom.
Any good ideas on what will take this off and not damage the plexi?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
AtomSmasher
    • Atomic-Train
Re: Adhesive Remover
« Reply #1 on: May 19, 2006, 11:06:20 pm »
soap, warm water, and a sponge or wash cloth.  Soak the plexi for several minutes in the soapy water and the glue will come off easy.
JeepMonkey
« Reply #2 on: May 19, 2006, 11:22:39 pm »
Thanks.  I'll give it a try.
kingflynn
  • Last login:May 01, 2023, 07:39:02 am
« Reply #3 on: May 20, 2006, 02:23:41 pm »
WD-40
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
« Reply #4 on: May 22, 2006, 09:11:28 am »
I second WD-40.
Dartful Dodger
  • Newer isn't always better.
« Reply #5 on: May 22, 2006, 01:46:37 pm »
Goo Gone, let it soak in.
woodygjw
  • Last login:August 26, 2012, 09:33:59 pm
« Reply #6 on: May 22, 2006, 09:41:16 pm »
I am a smoker, so I use this:
woody
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #7 on: May 24, 2006, 08:18:28 am »
Use some of these stronger chemicals on plexi with caution.  You don't want to haze the finish.
Hoagie_one
  • Um....whats a cabinet
« Reply #8 on: May 24, 2006, 09:03:51 am »
just use peanut butter.  works great, seriously
