Author Topic: Suggestions on which Pinball frontend to use with mamewah....  (Read 2854 times)
rbarr110
  • Last login:Today at 12:10:10 pm
  • I already built my own arcade controls!
I want to add a few tables to my mame machine and still access via Mamewah.
I am assuming I would just use a command line dos version of pinmame and not any other frontend if I would like to launch from Mamewah, is that correct?
I am still new to setting up Mamewah, still cant get figure out how to get different game lists generated by game type ( i.e. fighter, vector, 4-way, etc...)  So getting it to load a different emulator besides mame may take me a while to figure out.
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
Re: Suggestions on which Pinball frontend to use with mamewah....
« Reply #1 on: May 17, 2006, 06:51:03 pm »
I just launch right out of mamewah, using Howard's wrapper.  Here's my ini file if it helps:
### PP_Pinball.ini (mamewah v1.62) ###
emulator_title                            Visual Pinball
### List Generation Settings ###
rom_path                                  C:\Program Files\Visual Pinball\tables
rom_extension                             vpt
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines             C:\Program Files\CPViewer\cpvw.exe -r="[name]" -c=[cloneof] -e=0 -l="c:\program files\cpviewer\layout files\a2600 1280x1024.lay" -i="c:\program files\cpviewer\n64_controls.ini"
emulator_commandline                      C:\Program Files\Visual Pinball\tables\vp-launch4.exe "[name]"{nodosbox}{cursor}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\Program Files\Visual Pinball\Tables
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       0
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
### Settings used by MAMEWAH ###
current_list                              1
mccoy178
  • Go Bucks!
« Reply #2 on: May 17, 2006, 08:20:17 pm »
I second Howard's wrapper! :cheers:
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #3 on: May 18, 2006, 07:24:38 am »
I say chit-can Visual Pinball because of it's cabinet unfriendliness and go with Future Pinball.
John
« Last Edit: May 18, 2006, 07:53:15 am by jcrouse »
mccoy178
  • Go Bucks!
« Reply #4 on: May 18, 2006, 07:48:55 am »
I have no problems on my cabinet ya' old fart!  ;D :cheers: (Thanks for replying to my PM btw :angry:)
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #5 on: May 18, 2006, 07:50:13 am »
Hi,
you could check AtomicFE  "pinball" plug'n play module. It allows to run future pinball, Vpinball+vpinmame directly from the Front End.
Loot at configuration files , and i think you should find easily a way to do the same thing with Mamewah.
jcrouse
    • CPViewer
« Reply #6 on: May 18, 2006, 07:55:10 am »
Youki
I am curious how you handle some of the dialog boxes that pop up before the game launches, like version selection, instructions and so forth. Does you FE automatically handle these boxes and take you directly to the game?
John
jcrouse
    • CPViewer
« Reply #7 on: May 18, 2006, 07:56:23 am »
Obviously you haven't a clue, as usual.
 :laugh2:
John
youki
    • Atomic Front End
« Reply #8 on: May 18, 2006, 08:16:34 am »
Youki
John
Hi John,
I didn't really try myself that module (angelscry made it for me) , but i know you can run  directly the tables.
You select the table in Atomic ,  Atomic load Futurepinball or Vpinball/vpinmame and run the table for you and you are ready to play.
Have a try , Atomic used with plug'n play modules doesn't requires  configuration.
Download Atomic , install it.  (no configuration)
Download the Pinball module, install it.
Before running Atomic for the first use :
-run VPinball (included in the module) and install it (with default parameters)
-Double click on "pinball.reg" to register param.
Copy your tables  (.VPT or .FPT file) in the Tables folder.
then now, you can run Atomic.exe , select your table , and play.
mccoy178
  • Go Bucks!
« Reply #9 on: May 18, 2006, 11:10:58 am »
Seriously, with Howard's wrapper, it has always worked perfectly.
rbarr110
« Reply #10 on: May 18, 2006, 04:51:25 pm »
Ok - been searching for info on Howards Wrapper but I mostly come up with questions about it and not alot of information on what it is and where to get it.
Any ideas to where I can find out more info?
jcrouse
    • CPViewer
« Reply #11 on: May 18, 2006, 05:00:14 pm »
All of Howard's stuff is available here:
http://www.oscarcontrols.com/lazarus/
Enjoy,
John
  • Last login:Yesterday at 11:51:54 pm
« Reply #12 on: May 18, 2006, 05:15:45 pm »
The questions on it usually involve a specifc table that isn't behaving correctly.  So far it has always been the fault of the table (the code that activates the pinmame display is sometimes done in a crazy way).
As mccoy said, the wrapper always works.  I made the stinking thing almost 4 years ago and still the only time I have to update it is when I want to add new features.
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #13 on: May 22, 2006, 03:38:13 pm »
Also of note:
Visual Install Pack will help you install Visual Pinball, Visual Pinmame and all it's various dependancy's (a non trivial task for even an experienced techie):
http://www.vpforums.com/forum/showthread.php?s=&threadid=37115
Joseph Elwell.
