Author Topic: headkaze: Any chance ......  (Read 1254 times)
unclet
« on: May 16, 2006, 10:31:05 pm »
Any chance you could make your UAE Configuration file work with ZIP files, since WinUAE supports ZIP files now .....  I tried using the UAE Configuration file with all ZIP files and nothing happened, so I am assuming your application only works with ADF files as input rather than ZIP.
headkaze
  • 0x2b|~0x2b?
Re: headkaze: Any chance ......
« Reply #1 on: May 17, 2006, 09:09:44 am »
Hey unclet, I posted the source on another thread! Your a coder no? Why not take over the source and write something better. I really don't have the time to work on it anymore sorry.
unclet
« Reply #2 on: May 17, 2006, 09:56:28 am »
Ok, just thought I would try you first ....
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: May 23, 2006, 06:28:51 am »
Although its just a 3 letter change in the code, I would guess you could quickly do a:
rename *.zip *.adf
Run the config tool.
Then, rename *.adf *.zip
which would work (assuming you ONLY have zipped adf's in one directory). As its just reading the filenames....
unclet
« Reply #4 on: May 23, 2006, 07:11:40 am »
I figured the size difference is really not a problem since most Amiga games a quite small.    Unzipping them all at once was really no big deal either.    I already generate all the UAE files I need and I am learning that the whole Amiga experience is just not worth the effort .... as you have read in my other post at BYOAC.
Anyway, I really do appreciate headkaze's tool ..... I would never have spent the time configuring the games one at a time ..... just too many of them to do .....
