Author Topic: Layout help.  (Read 1051 times)
bulla
  • Last login:June 21, 2023, 04:14:30 pm
Layout help.
« on: May 15, 2006, 01:39:17 pm »
Could some kind soul check the layoutlay file pasted in below and tell me if they spot anything untoward ? Basically its a copy of the B&W Snes layout from the CPViewer site. When I opened it in the layout designer it wasnt showing the main.jpg file so I pointed the Designer to the main.jpg and everything looked fine. I then saved it and copied it over to my Cabinet.
Upon installing from zip in Mamewah config the new layout appeared but had no name and no preview pic but I selected it anyway. Upon loading mamewah I get no main.jp displayed and just a game list in a new font. Any ideas ? I've tried changing the link to main.jp in the layout.lay to the full path but no change.
Any help much appreciated.
Here's the layout.lay
640;32;60
 480
 0
 0
 10485760
 16777215
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 305
 21
 416
 82
True
 0
 8421504
 16777215
Arial
True
False
 12
 2
 400
 418
 159
 22
False
 1
 0
 13408512
System
True
False
 9.75
 2
 737
 23
 143
 23
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 44
 139
 230
 294
False
 0
 8421504
 16777215
Arial
True
False
 8.25
 2
 479
 378
 136
 15
True
 0
 8421504
 16777215
System
True
False
 9.75
 2
 363
 139
 230
 230
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 328
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 336
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 344
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 352
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 360
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 368
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 376
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 384
 40
 320
 277
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 392
 40
 320
 277
False
 0
 8421504
 13408512
System
True
False
 9.75
 2
 84
 566
 408
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 540
 569
 455
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 85
 596
 407
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 84
 627
 406
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 545
 656
 446
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 541
 690
 454
 20
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 544
 728
 455
 20
240;32;60
 260
 0
 0
 10485760
 16777215
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 12
 11
 214
 16
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 12
 29
 213
 154
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 12
 191
 214
 15
True
 0
 8421504
 16777215
Arial
True
False
 8.25
 2
 13
 211
 213
 38
265;32;60
 206
 0
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 13
 25
 239
 16
True
 0
 8421504
 16777215
Arial
True
False
 8.25
 2
 14
 63
 237
 88
True
 0
 8421504
 11121252
Arial
True
False
 8.25
 2
 13
 159
 239
 31
True
 0
 8421504
 16777215
System
True
False
 9.75
 2
 0
 0
 1024
 720
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 524
 0
 500
 400
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 0
 401
 1024
 87
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 30
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 40
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 50
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 60
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 70
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 80
 0
 640
 430
False
 0
 8421504
 16777215
System
True
False
 9.75
 2
 90
 0
 640
 430
True
 1
 0
 13408512
System
True
False
 9.75
 2
 0
 726
 1024
 20
True
 1
 0
 16777215
System
True
False
 9.75
 2
 0
 748
 1024
 20
« Last Edit: May 15, 2006, 02:03:01 pm by bulla »
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
Re: Layout help.
« Reply #1 on: May 15, 2006, 05:58:19 pm »
hmm... well I am not sure what is going on with your layout, but a quick note... when you open a layout in the Mamewah Layout Designer, by default it does not show the background, even if it has been configured. That's ok, it doesn't need to, as long as there is a 'main.jpg' file in the same folder as the layout file you should be fine.
bulla
Re: Layout help.
« Reply #2 on: May 16, 2006, 05:22:43 am »
Ah ok, thanks, maybe I'll just try and create my own and see hopw I go then.
Bulla
jcrouse
    • CPViewer
Re: Layout help.
« Reply #3 on: May 16, 2006, 10:14:00 am »
The path lines in the lay file can be empty. I try to keep them all empty so it doesn't find a bad path when moving them from machine to machine. In order to find the images the images simply need to have the proper name and be in the proper folder.
John
