Author Topic: T-Molding Router-Bit  (Read 16841 times)
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
« on: March 02, 2003, 09:48:24 am »
Anyone wants to sell/trade his T-Molding router bit?
Auntie MAME
  • Last login:September 09, 2007, 09:18:00 pm
  • badges, we don't need no stinkin' badges!
Re:T-Molding Router-Bit
« Reply #1 on: March 04, 2003, 10:37:55 pm »
ripzone
« Reply #2 on: March 05, 2003, 02:06:57 pm »
Check your PM, Auntie MAME!
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #3 on: March 12, 2003, 10:24:26 am »
Don't buy that 5/64" cutter, the slot is too wide for t-molding, I used it and I will have to glue my Tmolding into the slot!
Wade
Auntie MAME
« Reply #4 on: March 13, 2003, 12:01:29 pm »
I used the 5/64 bit with Happ t-molding and it worked perfectly.
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #5 on: March 19, 2003, 06:45:51 pm »
hmm  so do you need a different bit for all the various types?  T-molding.com sells a slot cutter that supposedly does it all.. and its width is 0.075" which works out to 4.8 / 64ths  or about 5/64ths..  beats me... ???
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #6 on: March 20, 2003, 01:11:49 pm »
I got the 5/64" bit that was recommended on this board, and T-molding.com t-molding where they recommend a slightly smaller groove.  I didn't think the 3/100's of an inch would matter, but it did!
Happ Controls t-molding might have a slightly thicker spine, but I kinda doubt it.  It may be that some materials work better with different width cutters, too.  Who knows.  All I know is I have to glue my t-molding into the grooves and I wish I could just tab it in with a mallet instead.
Wade
medley
  • Last login:November 27, 2006, 10:23:05 pm
« Reply #7 on: March 21, 2003, 07:28:59 pm »
ok, for 3/4" T-molding I used a 1/16"(.0625") router bit.
I'm not sure about the depth, but it was the only 1/16 bit that sears had.
It worked great.
« Last Edit: March 21, 2003, 07:30:10 pm by medley »
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« Reply #8 on: March 23, 2003, 08:39:50 pm »
I've been using Joe's idea from his Savoia Arcade site & it has worked well.
http://www.geocities.com/gijoekerr/
It consists of using a Dremel with a guide attachment & a carbide cutting wheel.
The wheel cuts like nobody's business.
I always do a couple of practice cuts & fits with a piece of drop-off & scrap t-molding just to make sure that I've set the depth properly.
I use T-molding.com's stuff & it fits tightly into the slot.
I have to use a rubber mallet in order to drive it in all of the way.
I get a lot of use from both the guide & the cutter.
If you forget to drill your plexi at the same time as your panel (come on I know that I'm not the only one who has done this), you can fit the plexi to the panel & use your Dremel with the guide & a small drill bit to match-cut the button & stick holes.
The tungsten carbide cutter also works great on metal, plexi or anything else for that matter (including flesh so be carefull).
Hope this helps.
Z
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #9 on: March 23, 2003, 08:42:33 pm »
Hope this helps.
Z
I looked everywhere and couldn't find one of those.  Where did you get yours?
Zeitgeist
« Reply #10 on: March 24, 2003, 01:15:46 am »
The local WallyWorld stocks 'em here for about $15 each.
I also saw them at the Home Depot.
In case you can't get them @ your local Wal-Mart, here's a couple of links:
http://www.walmart.com/catalog/product.gsp?cat=51199&dept=5428&product_id=1215240&path=0%3A5428%3A51199%3A4093%3A55338%3A55341
http://www.walmart.com/catalog/product.gsp?cat=51199&dept=5428&product_id=1218385&path=0%3A5428%3A51199%3A4093%3A55338%3A55340
OOPS.
According to the link, you shouldn't use the carbide wheel for metals - too late I already have.
Here's a diamond cutter designed for metal if you think you'll need it:
http://www.walmart.com/catalog/product.gsp?cat=51199&dept=5428&product_id=1218362&path=0%3A5428%3A51199%3A4093%3A55338%3A55341
« Last Edit: March 24, 2003, 01:23:38 am by Zeitgeist »
