Author Topic: Where to find +5 volts on Mad catz Dreamcast pad?  (Read 2321 times)
J_Talbain
  • Last login:April 23, 2003, 06:42:49 pm
« on: March 01, 2003, 05:19:58 pm »
Anyone know where it is because I am installing a P360 joystick?  Thanks in advance.
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Where to find +5 volts on Mad catz Dreamcast pad?
« Reply #1 on: March 02, 2003, 03:04:24 pm »
From heresay: The +5V in the pad is not enough to power the P360s properly, you need to get another +5V power source. (A 5 volt power adapter from Radio Shack should work)
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: March 04, 2003, 12:43:04 am »
I don't think its been confirmed yet.  Also, I foresee possible problems using an external power source (since you will then be combining the grounds of the DC and external source).
Vol
  • Last login:June 25, 2007, 11:02:18 am
  • Mame Kabinet II in the works!
« Reply #3 on: March 04, 2003, 06:40:37 am »
This page may help you find what you need:
http://mc.pp.se/dc/controller.html
