Author Topic: Rainbow LED Circuit v.2.0  (Read 2687 times)
rdagger
« on: April 29, 2006, 04:55:42 pm »
Here are a few pics of a new RGB LED board I built.  It is still a work in progress and the pics don't do it justice.
This latest version can drive multiple RGB LED's (as much as your power supply can handle).  There are now 3 dual digit colored coded LED displays that show the color.  The board can produce over 200,000 colors (64^3).  There are 2 modes.  Mode 1 allows you to specify a color using the 3 potentiometers.  Mode 2 fades through the different colors and the potentiometers controls the speed.  I'm still waiting for the color matching knobs and the mode toggle switch to arrive.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
Re: Rainbow LED Circuit v.2.0
« Reply #1 on: April 29, 2006, 10:24:05 pm »
Wow, nice functionaility and CLEAN!
An ounce of image is worth a pound of performance.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: April 30, 2006, 06:34:16 pm »
Nice work! How much did it cost you to put together??
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
rdagger
« Reply #3 on: May 01, 2006, 12:53:28 am »
Best Regards,
There are about $20 worth of parts, but most of them I had laying around.  Here is a parts list:
« Last Edit: May 01, 2006, 12:58:58 am by rdagger »
Fozzy The Bear
« Reply #4 on: May 01, 2006, 07:19:41 am »
Wow! that's not bad at all!! Is there any chance that you'll be selling circuit boards for this??  I'd be interested in a bare board or even a complete kit.
Best Regards,
rdagger
« Reply #5 on: May 01, 2006, 12:34:23 pm »
Best Regards,
I've been very busy at work.  Also, I am still not completely done with the code.  An RGB LED does not fade at a linear rate.  Therefore, I'm still fine tuning the math to better model the curves.  When it is finalized, I will post all the plans and code on my site so you can build it yourself.  If there was enough demand for the circuit boards, I'd consider sending a batch out for manufacturing but the cost to have the 3x4.5" double-side boards manufactured would be on the expensive side.
rdagger
« Reply #6 on: May 04, 2006, 02:32:34 pm »
Added matching color knobs and the mode switch.
