Author Topic: xbox360 controller and MAME  (Read 4670 times)
squirrellydw
« on: April 27, 2006, 11:51:33 am »
I am trying to configure an xbox360 to work with MAME so my mom can play some games instead of using the keyboard.  I can't seem to get MAME to work with it, any idea?
I b**ch. People listen!!
_Iz-
  • Last login:Today at 12:28:03 am
  • Time to coin up!
Re: xbox360 controller and MAME
« Reply #1 on: April 27, 2006, 11:54:03 am »
Does the controller show up in the windows control panel?
Did you enable joystick support in mame?
squirrellydw
« Reply #2 on: April 27, 2006, 12:05:12 pm »
Yes and Yes, I have tried to go into the setting for all games also and nothing.  I know I must be missing something
ArcaMan
  • Last login:July 29, 2008, 05:15:10 pm
    • Man Tripping
« Reply #3 on: April 27, 2006, 03:40:03 pm »
Do any of the sticks/buttons work?
Since there are three sticks on the controller, you may need to make sure you select the apropriate one.
I had to fiddle a bit with mine when I tried it but unfortunatly I didn't think about what I was doing or remember :)  I just did it.
James
Man Tripping: Guy's Getaways and Mancation Ideas!
http://www.mantripping.com
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #4 on: April 27, 2006, 03:45:30 pm »
u might have probs cause the xbox 360 controller is COMPLETLY analog with pressure sensitive buttons and junk
id say go buy a cheap pc controller
Slow In Fast Out
squirrellydw
« Reply #5 on: April 27, 2006, 06:19:48 pm »
Everything works fine under the control panel.  If I can't figure it out in a day or two I am going to return it for a cheaper one.
GoPodular.com
  • Last login:April 23, 2008, 10:09:55 pm
    • GOPODULAR!
« Reply #6 on: April 27, 2006, 10:51:56 pm »
Take a peek at my tutorial on setting up gamepad configs (for MAME32 but easy enough to port over to command line versions):
http://www.gopodular.com/mame_32_emulator_setup_tutorial/index.htm
Since the 360 controller D-pad is seen as a POV hat in windows, the variables you need to assign are:
J1_HAT_SWITCH_U
J1_HAT_SWITCH_D
J1_HAT_SWITCH_L
J1_HAT_SWITCH_R
IIRC, that's accurate.  Post back if you need help or if I'm wrong.  I'm working on some 360 stuff right now anyhow.  Besides, tomorrow is Friday.  :applaud:
combobreaker
  • Last login:December 25, 2017, 05:10:49 am
« Reply #7 on: May 01, 2006, 05:43:49 pm »
Works on my Pc. You have to install the 360 drivers from www.windowsgaming.com before connecting the controller and it should work just like any other controller.
GoPodular.com
    • GOPODULAR!
« Reply #8 on: May 01, 2006, 06:52:48 pm »
Are those drivers any different than the official drivers?
