Author Topic: MAME 105 and tballs...  (Read 2191 times)
KillerArcades
  • Last login:January 22, 2009, 02:09:39 pm
« on: April 26, 2006, 01:31:05 pm »
So, I'm setting up the latest version of MAME, and it looks like I have to edit the centipede.cfg file in order to use my trackball now...?
Anyone have a sample centipede.cfg they could share, or words of wisdom on just what I should add to the cfg file to get it to work?
Thanks,
yeah, that's right.
ahofle
    • Arcade Ambience Project
Re: MAME 105 and tballs...
« Reply #1 on: April 26, 2006, 01:46:21 pm »
You don't have to edit the cfg.  Just go into the tab menu in game for 'input all games' and change all the paddle and track devices.
KillerArcades
« Reply #2 on: April 26, 2006, 01:54:07 pm »
yeah, the problem I have with that is when I go into that menu and try to change the input, etc. and I spin my tball (as the mouse, right?) nothing happens, like it doesn't recognize it.
I've got my mame.ini file setup with mouse=1 (ON) and my trackball=mouse1 (instead of the default setting of "keyboard").
Is there something else I need to do to get mame to recognize the tball when I spin it? It works in windows as my mouse without any problems...?
« Last Edit: April 26, 2006, 03:04:30 pm by SKondris »
yeah, that's right.
ahofle
« Reply #3 on: April 26, 2006, 05:15:52 pm »
I'm assuming you made sure you have the mouse enabled in mame.
Try it again, but be very careful to only spin in the X or Y direction.  I had a little trouble at first too with it recognizing my trackball.  Also, don't 'spin' it per say, just quickly move it up or to the right (for Y or X respectively).  See if that works for you.
miles2912
« Reply #4 on: April 26, 2006, 09:10:06 pm »
My Spinner is plugged into the PS2 port and the trackball is on a mini-pac.  Enabling mouse support lets the spinner work just fine.  To get the trackball working I tabbed into the config screen for each TB game and set the X an Y axis by just moving the trackball.  In my mame.ini trackball=keyboard still.  Kind of a pain.
Don
KillerArcades
« Reply #5 on: April 27, 2006, 12:14:26 pm »
Thanks for the help guys, I figured out what I was missing. Between my ledwiz, IPAC and trackball, I had three things plugged into USB ports, and my trackball needed to be set to:
mouse 2
instead of mouse  1
apparently mame's seeing my trackball as my "second mouse"...?
anyways, it's working thanks!
yeah, that's right.
