Author Topic: Coin Door Questions  (Read 1217 times)
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
Coin Door Questions
« on: February 28, 2003, 03:25:00 pm »
hello all...
i have a few questions about coin doors.
first of all, is it possible to wire up a 2-player coin door for 4-player games? how would i do this?
second, let's say i get this over/under door from happ:
http://www.happcontrols.com/coindoors/40094600.htm
i'd also get the enslosure and the cashbox. is this all i need?? is this thing ready to be wired up for mame? or is this just a door and i need some internal stuff??
if you guys could point me in the right direction, that'd be great.
TIA!
Matan
  • Last login:March 05, 2003, 10:16:01 am
Re:Coin Door Questions
« Reply #1 on: February 28, 2003, 03:51:14 pm »
if it's a mame cab just set the p3 and p4 coin as the same keypress as the p2 and p1 coin
if it's a real cab i see no reason why you can't lead 2 wires from the coin door insted of 1
eightbit
  • My cab is never done...
« Reply #2 on: February 28, 2003, 05:14:25 pm »
You'll get 2 credits for every coin you insert or for every press of the button. If that isn't a problem for you then that method would work.
You can also use a shifted input or combination key input to get those if you wanted.
