Author Topic: Off-topic general computer question  (Read 1697 times)
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« on: April 23, 2006, 03:35:43 pm »
Are there any dangers to having a CD drive oriented vertically? I know the playstation two stands used to orient the CD vertically and I always wondered if there is damage to the disks. Would the same apply for PC CD-rom drives?
I had to beat them to death with their own shoes...
kevink
  • Last login:November 30, 2006, 06:33:38 pm
Re: Off-topic general computer question
« Reply #1 on: April 23, 2006, 07:34:21 pm »
I've seen some Flex designed cases built to work that way.  As long as your CD/DVD drive has four little tabs sticking out in the tray to hold the disk there shouldn't be a problem.  I know for a fact Gateway used to make PC's like this.
quarterback
« Reply #2 on: April 23, 2006, 11:23:45 pm »
I've had CD roms and hard drives that specifically state that they can be mounted horizontally or vertically.   You should just check the specs/manual for the CDrom drive you own.
-- Chad Tower
testicle187
  • Last login:April 10, 2025, 05:29:07 pm
« Reply #3 on: April 23, 2006, 11:24:47 pm »
I've always been under the impression that the vertical stand was the main cause of damage to the laser of the PS2.  It seems that gravity would pull the lens down a bit and wear out the motor.  I know they quit selling the vertical stands, and replaced them with the horizontal stands.  So, I would avoid the vertical drive if possible.
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #4 on: April 23, 2006, 11:44:13 pm »
But if you notice all of the next gen systems are vertical.  The ps2 just had problems with the lens in the early models.
17 years old and totaly addicted.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #5 on: April 24, 2006, 02:51:29 pm »
Supposedly it doesn't make a difference anymore (espicially if you have tabs like kevink said)
Personally, I have had better luck with them mounted horizontally..but if you need vertical...go for it!
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #6 on: April 25, 2006, 05:53:30 am »
All next gen consoles are DISPLAYED vertical..
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #7 on: April 26, 2006, 01:33:00 pm »
The center of gravity of the spinning disc will be off a tiny tiny bit. This would cause slightly more wear on the motor but we're probably only talking a month or so off it's total life span. Before that comes about, a new console will be out anyways.
Now if you want to destroy a CD/DVD drive quickly, use discs with those nasty adhesive labels. That throws out the center big time.  :)
Now in a tasty new flavour.
ha-Y-n
  • Last login:November 29, 2007, 06:16:07 pm
  • Shaka braddah
    • www.brianDAhawaiian.net
« Reply #8 on: April 26, 2006, 02:16:13 pm »
like mentioned before, if you have the tabs then its all good
Harry Potter
  • Smite-bait
« Reply #9 on: April 26, 2006, 10:43:52 pm »
The tabs don't do anything except prevent the disc from falling out when inserting and ejecting. Once the spindle grabs the disc, they don't matter.
