Author Topic: As of Mame 0.105 hi-scores clear after F3 reset?  (Read 1863 times)
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« on: April 21, 2006, 09:37:00 am »
Has anyone noticed that as of Mame 0.105 if you push F3 to reset a game the hi-score file clears out?  ???
Am I doing something wrong? Or is it the same for everyone?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: As of Mame 0.105 hi-scores clear after F3 reset?
« Reply #1 on: April 21, 2006, 12:41:07 pm »
This might have to do with the hard vs soft reset.  Check this thread and see if it applies to you.  Note that they talk about 0.105u1, which might be different from 0.105, since reset has been changing recently.
Robin
Knowledge is Power
RetroBorg
« Reply #2 on: April 21, 2006, 09:19:02 pm »
I had read that thread before when I was trying to work out the problem, I believe F3 is actually doing a hard reset when it should be doing a soft reset, I have even remapped hard reset to a completely different key but I still get the same result.
Can someone else please see if they have the same trouble, make sure if you want to keep your high score to make a backup of it first though.
