Author Topic: wiring power and pause to same button. safe to do so?  (Read 1782 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: April 20, 2006, 12:40:43 am »
is it safe to wire power button from PC and pause wire from IPAC4 to same button on my CP?
here's the drawing how i plan to wire it.
My website: www.bossyman15.com Lots of arcade pictures inside!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: wiring power and pause to same button. safe to do so?
« Reply #1 on: April 20, 2006, 12:53:22 am »
Is this question for real?
bossyman15
« Reply #2 on: April 20, 2006, 12:55:23 am »
umm yes just to be safe than sorry.
by that respond i guess that means yes?
AtomSmasher
    • Atomic-Train
« Reply #3 on: April 20, 2006, 02:10:47 am »
well.....it is safe to do so, it shouldn't hurt anything, but every time you try to pause a game your computer will turn off.
bossyman15
« Reply #4 on: April 20, 2006, 02:16:07 am »
that's no problem i can tell winxp not to turn off when i push the button.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #5 on: April 20, 2006, 02:19:51 am »
Then how do you turn it off?  You going to wire up another button for "off"?  And what's XP going to do when you push it, then- sleep mode?
bossyman15
« Reply #6 on: April 20, 2006, 02:24:13 am »
my pc will turn off if you hold it for ~5 seconds but also doesn't mamewah have power off feature as well?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: April 20, 2006, 02:42:16 am »
You can have mamewah escape straight to whatever you want without going through the menu.  I didn't know if you were serious because having the power button and the pause button together doesn't make much sense to me.  On a side note, I know that someone made a batch file that would make it so the escape button had to be held in for two seconds before a game would be existed to avoid accidental escapes in the heat of battle.  I plan on having a power button out of normal reach, and using a shaaazam button to escape games.  I would love to use the pause button as a shift as well so that both would have to be pressed to exit a game.  I'm still researching that option.
BTW, didn't mean to leave such a rude first response, it was my first reaction.
