Author Topic: Mamewah and emu's  (Read 1883 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
Mamewah and emu's
« on: April 19, 2006, 01:50:17 pm »
I am using mamewah but want to add an n64 emulator (project64), and snes emu, genesis emu and a nes emu how do i do this ?
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: Mamewah and emu's
« Reply #1 on: April 19, 2006, 03:04:36 pm »
Marky_1979
    • Personal Webspace
« Reply #2 on: April 19, 2006, 06:28:31 pm »
many thanks im using an old version of mamwah will that effect my sega genesis emu? as for some reason i cant get it to work an when i run it theres no sound for some reason. cant think what it could be? is there something i could have pressed to mute it? or a setting in fusion or mamewah?
« Last Edit: April 19, 2006, 06:49:29 pm by Marky_1979 »
« Reply #3 on: April 20, 2006, 06:44:21 am »
Get Fusion to work properly on it's own, and then run it from Mamewah.  Mamewah will not affect how any emulator operates.
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #4 on: April 20, 2006, 07:49:04 am »
For Best results...You should use the Latest available version of mamewah.
Marky_1979
    • Personal Webspace
« Reply #5 on: April 20, 2006, 03:39:36 pm »
What is the latest version and where is it i have 1.6 at moment i think
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #6 on: April 21, 2006, 07:41:43 am »
It's not going to matter if it's the latest version, although, the latest version  will run better in the end.
Do as Minwah suggested, get Fusion running properly on it's own first, then incorporate into Mamewah.
