Author Topic: Return to Center Happs Shifter question  (Read 1061 times)
« on: April 18, 2006, 01:54:03 pm »
I have this shifter for my driving cabinet -
http://www.happcontrols.com/driving/50008300.htm
The turbo button on the handle has a wire sticking out that is some sort of 2 prong molex connector. Does anyone know how I can connect this to an ipac? I assume cut the molex connector off and run the ground to one and the other wire connects it to the ipac as a button. I'm used to having 3 connectors a ground, NC, and NO plug.
Am I understand this right?
Flinkly
Re: Return to Center Happs Shifter question
« Reply #1 on: April 18, 2006, 02:18:48 pm »
a button usually only uses 2 of the three plugs.  think of it as a pushbutton which you usually make NO.  The turbo button is probably the same and hook up just like you said.
