Author Topic: Wiring a basement for an arcade question?  (Read 4210 times)
GGKoul
  • Cheesecake Apprentice
  • Last login:May 26, 2024, 02:06:23 am
  • I was once a big man!! -4700 posts later...
« on: April 17, 2006, 02:59:19 pm »
Hello
I'm in the process of wiring my basement for my arcade collection.  (2 pinballs, 2 twin racers, 2 - 3 arcade units).  Which will be all against one wall.  Presently there is 4 plugs on the wall.  But there is a discussion about what type of wire require.
One person says, the 14 gage (15amp breaker) wire should be good enough .  But then my other buddy says I should get a 10 gage (30amp breaker) for those 4 plugs.  So I'm not sure...
Just wondering what other people's thoughts are?
-GGKoul
« Last Edit: April 17, 2006, 03:12:30 pm by GGKoul »
grantspain
Re: Wiring a basement for an arcade question?
« Reply #1 on: April 17, 2006, 04:39:34 pm »
given the option i would always over rate the wiring because if you wanted to you could add more cabs,the mistake they make in spain is they always rate the wire to the minimum ring breaker amps which is why i am having add extra circuits in our arcade,for the pennies it costs to go to a higher rating its worth it in the long run
GGKoul
« Reply #2 on: April 17, 2006, 05:09:15 pm »
so the question is... should I get a 12 gage (20amp) or 10 gage (30amp)?  I assume 12 gage as 10 gage is probably overkill.
grantspain
« Reply #3 on: April 17, 2006, 05:21:57 pm »
i would go 20amp,in the u.k we rate at 25amp
pointdablame
« Reply #4 on: April 17, 2006, 05:34:23 pm »
I think 12 guage/20amp would be fine for what you're doing, but it may be worth looking into price differences.  I don't have a clue what the differences would be myself, but since you are running wire anyway, if we're talking about a minor difference in price, it may be worth it to go "overkill" just in case.
first off your and idiot
GGKoul
« Reply #5 on: April 17, 2006, 06:41:54 pm »
I think 12 gauge/20amp would be fine for what you're doing, but it may be worth looking into price differences.  I don't have a clue what the differences would be myself, but since you are running wire anyway, if we're talking about a minor difference in price, it may be worth it to go "overkill" just in case.
Well, I framed the basement 2 weekends ago and my brother-in-law came by wired everything with 14 gauge wire, pot lights, switches and plugs, last weekend.  So since its just one wall (3 plugs) that are just getting re-wired.  I'm just going to purchase 60 feet of the 10 gauge and wire those up for 30 amp service.
I haven't bought the breakers yet.  So all is good.
BobA
  • What Me Worry?
« Reply #6 on: April 17, 2006, 09:10:24 pm »
Check with an electrician in your area.  If you wire 30 amp at the breaker box  you should have 30 amp recepticals.  If you have 15 amp recepticals and you overload the circuit you can still get 30 amps before the breaker opens.  Does not sound like a good situation.  A 30 amp receptical will not take a regular plug and a 15 amp receptical will not take a 30 amp plug.
Better to have more 15 amp circuits properly protected than a 30 amp circuit that is mismatched.
woodygjw
  • Last login:August 26, 2012, 09:33:59 pm
« Reply #7 on: April 17, 2006, 09:16:25 pm »
I agree with BobA.  You could put in 20 amp outlets with 20 amp breakers, as they will allow a standard plug.
20 amp outlet:
15 amp outlet:
30 amp outlet:
woody
« Last Edit: April 17, 2006, 09:34:08 pm by woodygjw »
nostrebor
  • SHOCKING!!
« Reply #8 on: April 18, 2006, 09:14:59 am »
12ga 20 amp with 20 amp recepticles is the way to go. If you think that you are goint to overload the 20 amp circuit, just pull 2 circuits and split the recepticles between them.
GGKoul
« Reply #9 on: April 18, 2006, 09:16:37 am »
Thanks for the update!!
So I'll purchase 20 amp wire and 3 - 20 amp outlet plugs with a 20 amp breaker... Sound good?
« Last Edit: April 18, 2006, 09:18:28 am by GGKoul »
ClubNinja
  • Last login:October 19, 2010, 12:46:02 pm
  • Comfortably Numb
« Reply #10 on: April 18, 2006, 04:08:55 pm »
Exactly.
BobA
  • What Me Worry?
« Reply #11 on: April 19, 2006, 11:18:37 am »
Sounds good to me too.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #12 on: April 20, 2006, 05:37:26 am »
We dont use gauges over here other then for car audio, but a normal power circuit is 2.5mm
zudmsc
  • Last login:September 07, 2011, 07:44:26 am
« Reply #13 on: April 26, 2006, 10:16:31 am »
A raised floor would be great for wiring.  Its too bad I cannot do that in my basement, not enough head room.  We have that floor at work in our computer room.
Zud
