Author Topic: Best, Easiest CP desinger prog to use?  (Read 1091 times)
lettuce
  • Make It So!
« on: April 16, 2006, 10:37:39 am »
Im going to start my new project soon, and will be starting by creating my CP first, what is the Best software to use?. Im currently experimenting with CP Sketcher, which seems pritty good, but would like a prog where u could import existing layout, as a template like, says standard templates, for 2, 3, 4 player layout, with different joystick, devices layouts, and then just fiddle about with them to change em to your liking, or one that has a setup wizard, that walks you though the whole process, i know im probably asking to much. I want my 4 player CP to be almost identical to the Slikstick Quad CP, but with a few minnor changes. Are the any measurements for this layout? Thanks in advance
