Author Topic: Console Controller to I-PAC?  (Read 2221 times)
CartmanDP1
  • Last login:October 08, 2008, 05:22:34 pm
« on: April 16, 2006, 12:23:11 am »
I've been thinking about setting up console controllers for my mame cab but am too poor/cheap to buy all those adapters. If I were to cut the ends off, could the wires be attached to an I-PAC or does it not work that way?
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
Re: Console Controller to I-PAC?
« Reply #1 on: April 16, 2006, 07:25:39 pm »
if you hack the controller wouldnt you be you be using the game pad as your thingy-ma-giggie.  Meaning you would not need the ipac.  Never hacked a pad but sound right...
CartmanDP1
« Reply #2 on: April 16, 2006, 09:06:13 pm »
I know they sell conversion kits at retrousb.com and sell other adapters elsewhere but what I am saying is if I cut the plug off say an SNES controller and strip the wires will there be a wire that represents each button so i can than attach it to an I-PAC? This just seems to be a cheap way out.
whatzcrackn
« Reply #3 on: April 16, 2006, 10:30:38 pm »
from what I understand, the i-pac is an encoder/decoder for the buttons and tells each button what to do.  If you hack a joypad, that encoder/decoder will already be in place, right.
The hacked pads I have seen, hook directly to the buttons, if I am not mistaken.  An for what it is worth, I am not an expert and have never hacked a pad,  use the search option and type in hacked______ what ever, you should be able to get some post on this topic.
Good luck and post what you find.  I will do the same!
« Last Edit: April 16, 2006, 11:53:03 pm by whatzcrackn »
whatzcrackn
« Reply #4 on: April 16, 2006, 10:36:40 pm »
two second search (hacked controller) and found this:
pics:  http://www.flickr.com/photos/vr/sets/439496/
reference:  http://forum.arcadecontrols.com/index.php?topic=38509.0
again good luck!!
CartmanDP1
« Reply #5 on: April 16, 2006, 11:09:02 pm »
thanks for the responces whatzcrackn, sorry i should really explain myself better, try #3, I already have an I-PAC and an arcade control panel but now that I'm getting into console emulators I want to be able to use the original controllers. So I want to plug an SNES controller into my PC, the only way I have seen to do this is to buy adapters or a USB conversion kit. This would be too expensive for me right now, so I thought that maybe if I were the take an SNES controller cut the plug off and expose the wire that there would be wires that correspond to each button so I could then plug that into the I-PAC and use the controlle on the PC. Possible?
whatzcrackn
« Reply #6 on: April 16, 2006, 11:42:31 pm »
Nuff said.  might work, good luck!  I did ebay snes to usb:
http://search.ebay.com/snes-to-usb_W0QQfromZR40
Seems alittle to much if you ask me.  ouch, so you want a joy pad connected to your cp?
« Last Edit: April 16, 2006, 11:50:53 pm by whatzcrackn »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #7 on: April 16, 2006, 11:48:58 pm »
i wouldnt do that ud have to do a weird rig if u wanted both
basically wire all of ur wire to both the controller and the ipac
Slow In Fast Out
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
« Reply #8 on: April 18, 2006, 10:32:41 am »
If a snes cotroller is like the nes controller just cutting off the end and attaching the wires won't work.  Your going to need to solder 13 wires to the pcb to get full functionality.  And then connect those wires to you ipac. You can also try using a parallel port like here.
blakes
  • Last login:May 07, 2008, 02:36:51 pm
    • http://www.neo-revelation.org/~neotek/arcade
« Reply #9 on: April 24, 2006, 12:26:31 pm »
I understand the quest for being cheap and all, but sometimes it's worth it just to spend a little extra money on high quality items.  I have 2 superjoy converters and I must say that they work beautifully.  You don't have to bother with making your SNES usb only (so you can still use them on an SNES if you want).  Just plug in the superjoy to usb, plus in the snes controller to that, and you're set.
As far as hooking them directly to the ipac, like other people on here have said - that just won't work.
