Author Topic: Any way of adding VGA to a Wells Gardner 25K7191 and not require ArcadeVGA?  (Read 1623 times)
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
I may be getting a Wells Gardner 25K7191 but I wanna know is there any way to add VGA connector to it without the need for an ArcadeVGA card on my PC?
I would also like to use this monitor with my Dreamcast (3rd Party VGA adaptor) and XBOX (VD-Z3 component to VGA transcoder)...
thanx for any advice! I already did a google search and search on these forums.
P.S. I don't think it is gonna come with a power cord so any help on plugging this into a standard power outlet would be helpful!
« Last Edit: April 10, 2006, 01:45:06 am by eastbayarb »
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Use either an Ultimarc video amp or a J-PAC.
eastbayarb
Peale,
are you saying that the JPAC will let me plug any PC video card to my arcade monitor (or any VGA device)?
Unfortunately, the monitor I am getting doesnt have a JAMMA connector
Ken Layton
  • Guru
  • Technician
WARNING: That monitor MUST be connected to an isolation transformer!
Do NOT attempt to plug the monitor directly to a wall outlet or considerable damage will result not only to the monitor, but to other devices connected to the monitor.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Those are 31.5k Signals, you cannot display those on a standard cga monitor.
Modify the dreamcast adaptor to do 15k and order the xbox adapter from ultimarc.
http://www.ultimarc.com/xba.html
The only other option is using a transcoder to covert all the 31.5k signals down to 15k.
Later,
dabone
