Author Topic: Swap Partition/drive in Windows  (Read 1125 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: April 08, 2006, 12:35:35 pm »
I know that when you set up a Linux system, it has you dedicate a whole partition of your drive to swap file. Can the same be done in Windows, or could you actually dedicate a seperate drive to swap?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
_Iz-
  • Last login:Yesterday at 04:43:16 pm
  • Time to coin up!
Re: Swap Partition/drive in Windows
« Reply #1 on: April 09, 2006, 12:44:34 am »
Yes, you can do the same in windows. Just create the new partition and move the swap file into it.
[Create Windows Managed Pagefile(s)]
Start menu, Settings, Control Panel, System applet, Advanced tab,
Performance - Settings button, Advanced tab, Change button, on the Virtual
Memory dialogue, first select a drive from the list, then click the
radio-button 'System managed size', press the Set button. select the next
drive from the list, System managed size, press Set, and so on. when you're
done, press OK, OK, OK. a restart will likely be required.
TIP - do NOT forget to press the SET button after configuring the pagefile
for each drive, (many people forget to press SET)
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« Reply #2 on: April 09, 2006, 09:31:57 am »
Just out of curiosity, how big is your page file?
192MB here.  I run lots of apps though, and I think this might be a tad small.
USSEnterprise
    • USS Odyssey
« Reply #3 on: April 09, 2006, 10:40:24 am »
800MB
quarterback
« Reply #4 on: April 09, 2006, 05:01:20 pm »
The swapfile is called PAGEFILE.SYS, right?
Mine is set for my C-drive, but I can't find it anywhere ???  Where is it?  I figured it'd just be in the root or C:/windows/
-- Chad Tower
