Author Topic: lcdtopgun smog driver mouse vanish?  (Read 1064 times)
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
« on: April 06, 2006, 09:37:26 pm »
I finally got a lcdtopgun loaded the latest smog driver, plugged in the gun,  calibrated the gun, and then tried to load the guncon2pc control panel.  Well, my mouse cursor is stuck in the lower left hand corner, and won't move out of that corner.  Unplug lcdtopgun, works fine.  Plugin lcdtopgun or guncon2 won't work. ;-(   I know I can't be the only one that this happens to, but search has failed me.
sWampy
Re: lcdtopgun smog driver mouse vanish?
« Reply #1 on: April 08, 2006, 12:22:07 am »
Fixed, after like 20 remove all drivers, delete registry entries, delete manually left files, resintall, test, ets.  Finally I hooked it up to my xbox, verfied the gun worked, hooked it back to the pc and it magically worked. ;-.....
