Author Topic: Visual Pinball Vpinmame Volume  (Read 3150 times)
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« on: March 31, 2006, 08:28:06 am »
I should probably be asking this at VPforums.  I will probably also try there.
I run Visual Pinball through GameEx.  I find that the pinmame volume is always extremely low.  It's usually way way out of sinc with the visual pinball sounds (flippers, bumbers, coin slot sounds)
Anyone have any experience with this.
If I poke around the INI files for pinmame will I find a global volume setting?
As it is, I've been going in and ramping up the volume on the tables where the designer has actually provided volume controls.  The problem is, once I have this PC permanently in my cabinet, it will mean I have to keep opening the keyboard drawer.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
