February 01, 2026, 12:49:50 pm
That seems to be for the Wico stick...mine is the one that came with the 360.But, if I had to cut it, what is the best thing to cut it with?
Quote from: dpz147 on March 29, 2006, 03:26:35 pmThat seems to be for the Wico stick...mine is the one that came with the 360.But, if I had to cut it, what is the best thing to cut it with?I think Wico and Happ buy from the same manufacturer. The Happ instructions also state that the sleeve (bushing) should be 1/2" for wood.I cut mine carefully with a small hack saw. You don't want to cut it too short.
isn't it supposed to come with both sized bushings and you just use the one you need for your panel?
