Author Topic: Lexan ???  (Read 1978 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Lexan ???
« on: March 20, 2006, 10:30:12 am »
hey guys 2 questions
1. how do you cut lexan & with what tool
2. where is the best place to get lexan
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: Lexan ???
« Reply #1 on: March 20, 2006, 10:35:44 am »
's all in the wiki ;) Lexan is Polycarbonate BTW...
http://wiki.arcadecontrols.com/wiki/Plastics
divemaster127
Re: Lexan ???
« Reply #2 on: March 20, 2006, 10:38:35 am »
thanks a bunch
AtomSmasher
    • Atomic-Train
Re: Lexan ???
« Reply #3 on: March 20, 2006, 10:41:09 am »
This tutorial has a good section on cutting plexiglass and lexan, http://spystyle.arcadecontrols.com/index1.htm
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
Re: Lexan ???
« Reply #4 on: March 20, 2006, 12:26:35 pm »
Save money buy acrylic.  Easy to cut and drill with a router while it's between two pieces of plywood.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
Ed_McCarron
Re: Lexan ???
« Reply #5 on: March 20, 2006, 01:37:23 pm »
You can cut lexan just like you cut wood or aluminum.  Its pretty tough, but easy to scratch.
Acrylic is more fragile - if a drill bit grabs kiss it good-bye.  Its tougher to scratch.
Both are pretty routable.
Depends on your preferences.
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
Re: Lexan ???
« Reply #6 on: March 20, 2006, 02:02:26 pm »
I purchasesed a 36"x48" sheet of Lexan at Home Depot for about $60.  I also purchased an acrylic cutting tool.  I used the "sandwich method" (MDF - Lexan - MDF) for drilling the  Lexan and used the tool to trim it to size.
I have attached some pictures of the tool.
« Last Edit: March 20, 2006, 02:11:59 pm by ChicagoDave »
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
miles2912
Re: Lexan ???
« Reply #7 on: March 20, 2006, 03:36:31 pm »
I have been working with Acrylic for my cab and have tested it out quite a bit.  What happens when you are drilling it is when you finally make the hole the acrylic wants to grab the drill bit and ride up or twist causing it to crack.  Once your hole is almost made then slow it down and if the material starts to ride up then stop.  I also do not hold it down securely so when it starts to ride up or twist, I let it.  As far as cutting the stuff I have had excellent results with a router and a pattern bit.  Measure and draw a line. Then clamp a straight edge on the line and follow it with the router.
Don
psychopanda
  • Last login:August 31, 2006, 01:13:17 pm
    • PsychoPanda's Secret Grotto
Re: Lexan ???
« Reply #8 on: March 21, 2006, 11:28:05 am »
Hmm, I saw that same acrylic cutting tool but neglected to pick it up. Does it cut better than a utility knife?
Lots of people have mentioned this already, but I found it most helpful to drill acrylic by first starting the hole a little ways, then switching the drill to reverse, and then switching back to forward and finishing the hole.  It seems the middle step, running in reverse, helps to warm up the acrylic before you make your final cuts. This method worked really well when using a spade bit to cut holes for joysticks and buttons.
ChicagoDave
    • Dave's Website
Re: Lexan ???
« Reply #9 on: March 21, 2006, 11:52:00 am »
Yes it does a better job than a utility knife.  It has a small "hook" at the end which actually grabs and strips the Lexan.  A knife would simply cut it without stripping it.  The tool worked great.  Scored 10 times and then cracked the piece off, perfect cut...
Homer Simpson:
emdkay
  • Last login:July 10, 2019, 09:53:25 pm
  • Authentic & Repro Arcade Artwork & Bartop Cabinets
    • EMDKAY - Authentic & Reproduction Arcade Artwork
Re: Lexan ???
« Reply #10 on: March 21, 2006, 12:49:24 pm »
If it's lexan for a marquee you're looking for, I've got 26.0" x 8.0" sheets - two for $9.95 shipped:  http://www.emdkay.net/marquees_custom.html  ;D
EMDKAY.net - Your Original Source for Authentic & Reproduction Arcade Artwork, Arcade & Mame Marquees, and Home Arcade Bartop Cabinets
Improve the lives of children with toys and games through Emdkay & Child's Play! - See specially marked products.
Frosty
  • Last login:December 30, 2021, 11:11:38 pm
Re: Lexan ???
« Reply #11 on: March 21, 2006, 07:21:31 pm »
Don't be afraid to get at it with a good router, either.  Works really well.
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
Re: Lexan ???
« Reply #12 on: March 22, 2006, 02:04:24 pm »
Hey, where's the eye protection???  :P
