Author Topic: Coin door/plate and cab suggestions  (Read 2489 times)
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
« on: February 23, 2003, 01:35:16 am »
Hey guys,
I'm starting work on a scratch-built cocktail cab and want to make sure I plan as well as I can.
I've decided to go with a variation of this design:
http://underworld.fortunecity.com/fifa/294/diagram.html
with the monitor mounted "vertically", i.e. player one and two face across the table on the "long side", with a side by side 2-stick panel on the horizontal.
(something like the "mondo-turtle-head" cab at www.smacksville.com
I'm still looking for a 20" or 21" arcade monitor (hopefully I'll pick one up here in Oz for a reasonable price) which is bigger than normal for a cocktail cab and means I need to modify all the dimensions some.
I'm also keen to use a coin door/faceplate design which is common in Australia but seems difficult to find anywhere else, that looks something like this:
It's listed at arcadeshop.com as a "nintendo coin plate/mech unit" at US$45.  - But I can't find any info on these anywhere!
Anyone have any info on this type of coin door - mounting dimensions, config options (i.e. can I change the coin setting)? Or indeed, does anyone have one they may wish to part with  :)
On other issues - I intend to leave room for a trackball also.  Probably a (slightly cheaper in Aus) used Atari. Any thoughts at this stage as to whether I should go a mouse hack or plump for one of those expensive happ interfaces?
On the construction side, a mate has suggested framing up the monitor supports (and perhaps the whole cab) with steel for strength. Every write-up i've seen just uses mdf/ply and some pine. Is steel a bit of overkill here?
Sorry for the long post - love to hear any comments you guys might have!
cheers
bviking
Shut up! Bloody Vikings!!
Re:Coin door/plate and cab suggestions
« Reply #1 on: February 23, 2003, 08:38:45 am »
I've got an old cocktail which uses a very similar coin thing - mine has 2 slots for 10p's and 50p's tho.  That is definately the type of coin entry you want for a cocktail - they look great.
My cocktail has a metal frame for the monitor to sit on - I think if I were to build one I would do the same...
MilitiaMan
  • Last login:May 28, 2011, 09:25:35 am
  • It's a fine line between hobby and mental illness.
« Reply #2 on: February 23, 2003, 09:27:19 am »
Viking,
I have at least one of those. I may even have 2 or more, if you need them.
Here is a photo of the actual component:
And here is another:
Let me know if you are interested either via PM or e-mail.
E-mail:  steven.moritz@attbi.com
OSCAR
    • Oscar Controls
« Reply #3 on: February 23, 2003, 09:31:39 am »
OzStick carries that style of coin acceptor, so you could avoid international shipping charges.  I'm sure Chris will help you out with dimensions and such if you email him, he's really good about that.
http://www.ozstick.com.au/
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #4 on: February 23, 2003, 10:56:59 am »
Don't forget that MilitiaMan's coin mechs are set up for american quarters.  Not much good in australia.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
MilitiaMan
« Reply #5 on: February 23, 2003, 11:12:23 am »
TRUE !!!
bloodyviking77
« Reply #6 on: February 24, 2003, 03:27:08 am »
Thanks heaps for the replies:
Think I'll get in touch with ozstick (thanks Oscar) due to locality - must have missed the parts section when I last checked those guys out!
Now to start the plans!
