Author Topic: monitor wiring help  (Read 1818 times)
JD
  • Last login:March 30, 2003, 02:04:39 pm
    • Linuxgaming
monitor wiring help
« on: February 22, 2003, 08:36:17 am »
After striping done my jamma cab I labeled all the wires, Only thing that looked strange was the monitor it has the following coloured wires
wire             jamma connection
red =                   green
green =                red
blue =                   sync
white =                 blue
This doesn't seem correct any help appreciated just waiting before I connect these
Monitor is Samsung 5019B22
JD
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:monitor wiring help
« Reply #1 on: February 22, 2003, 07:47:50 pm »
Color of the wireing is irrelevant, just make sure the correct signals go to the correct points on the monitor. Just go by what the Jamma pinout says. I've actually had the same color scheme on one of my Jamma harnesses as your harness has.
