Author Topic: TV advice... and SCART?  (Read 1385 times)
AustinPowers
  • Newbie
  • Last login:April 03, 2006, 10:01:57 am
« on: March 15, 2006, 04:49:22 pm »
I'm building a cabinet that can support a 27" or 33" screen (haven't decided which I'm doing). I figure my only feasiblely priced option is a TV, but can someone tell me if I'm setting myself up for a downside?
My ratio's would max out at 600x800, right? Is there any arcade game on Mame that I wouldn't be able to play?
Lastly, I've got a sufficient PC, but it currently runs with a Voodoo 3dfx graphics card, VGA out. I read a lot about SCART cards on other threads. Can't I just get a VGA to S-Video plug? What are the limitations?
Definitely a rookie here from the states and I'd appreciate any/all advice. Thanks!
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: TV advice... and SCART?
« Reply #1 on: March 15, 2006, 07:11:17 pm »
Lots of people use a TV and are very happy. A huge percentage of games in mame worked on what is essentially a TV in reality anyway.
There is direct 'plug' for VGA to S-video. The signals are completely different. You can get a converter, which is basically a seperate box that converts the VGA to a S-video signal (and will cost money). However, a huge number of extremely cheap graphic cards have a "TV-out" connector. IE they convert from VGA to S-video or composite on the graphics card itself. ATI has typically had a good reputation for tv-out quality, although Nvidia has improved in recent time.
SCART connectors are found on almost every european TV set. I do not know about the US - a lot less, I think. The advantage of scart is that it has seperate RGB signals - unlike S-video/composite - but like VGA. The frequencies are completely different, but using software you can make your VGA graphics card send a RGB signal to the TV (through the scart socket) that it understands and displays.
The important factor here is quality. RGB signals are the best quality, better than S-video. S-video is MUCH better than composite/RCA. This is why people go for it.
I've missed out loads of info here - it can get quite confusing! - but should help you start. Have a look in the projects page for someone who has used s-video. Several people are perfectly happy with that.
