Author Topic: need router bit name...  (Read 1461 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: March 14, 2006, 03:24:04 pm »
I already have slot bit for tmolding
so i need flush bit and this bit i dont' know the name of.
its used to route out some parts for trackball and other controls to be flush with CP top.
what's then name of that bit?
My website: www.bossyman15.com Lots of arcade pictures inside!
whammoed
  • Last login:January 31, 2026, 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
Re: need router bit name...
« Reply #1 on: March 14, 2006, 03:28:11 pm »
You can route out an area of wood with a regular "straight bit".  If you are talking about the kind of bit where a bearing rides along the edge so you cut in a certain distance, that is called a "rabbeting bit".
whammoed
    • NiceMite
« Reply #2 on: March 14, 2006, 03:30:08 pm »
miles2912
  • Last login:October 31, 2019, 05:30:24 pm
  • My first Home Game. Fairchild System F.
« Reply #3 on: March 14, 2006, 03:38:14 pm »
I used a straight bit to recess my trackball.  Layout the trackball template down and cut out the center section first and then drill the 4 holes.  Basically I just lowered the bit the same thickness as the trackball plate and then tested it out on a piece of scrap MDF.  Once I knew the distance from the edge of the router to the cut, I made some small marks on my CP and clamped a straight edge down and made the cut.  Once the outside edges were done it was easy to freehand out the middle.
Don
  Scratch built upright MAME Cab
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #4 on: March 14, 2006, 03:38:54 pm »
This should also help you out courtesy of timoe: How to make a Top Mount or Under Mount Joystick Jig
This opinion was created from 100% post consumed information.
