Author Topic: Any Options for a Translucent or Frosted handle on a Omni Prodigy?  (Read 1745 times)
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
I am committed to using a Prodigy from GroovyGameGear (committed sounds so negative, it's not).  My CP already has a slot for the lever to switch from 4 way to 8 way so that can't be changed.
Ideally, I'm looking for an illuminated ball handle with a frosted or clear translucent ball.  If I can't illuminated it, then a frosted or clear ball would be best, or a blue translucent ball would be acceptable (although I have trouble settling for acceptable).
Randy, I can't keep up with you (that also sounds negative but it's not) so it'd be great if you already have a replacement handle.  Othewise, are there other products out there that I could modify to get what I'm looking for?
This opinion was created from 100% post consumed information.
squirrellydw
Re: Any Options for a Translucent or Frosted handle on a Omni Prodigy?
« Reply #1 on: March 08, 2006, 03:56:55 pm »
doesn't slikstick make some of those??
I b**ch. People listen!!
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 08, 2006, 04:35:47 pm »
No but you might be able to modify the ones they do make.
Grasshopper
« Reply #3 on: March 08, 2006, 05:29:13 pm »
Maybe Randy and Christian could combine forces and come up with something.  :D
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: March 09, 2006, 09:29:25 am »
LOL  ;D ;D ;D
    • GroovyGameGear.com
« Reply #5 on: March 09, 2006, 02:45:22 pm »
It is a little known fact that for quite some time, the Prodigy Retro edition shafts have had a hole down the middle of the them.
The "Retro" style used to be available as an option under the Versa-Ball item.  I'll put it back if you are interested in such endeavors.
Wienerdog
« Reply #6 on: March 09, 2006, 02:55:32 pm »
Holy smokes, that IS a little known fact...  I have a non-retro in the control panel right now with a top mount, but I could switch that out with my retro that I have waiting for another project.  Based on what I see on your site, am I looking for Versa Ball replacement shaft with Translucent Sapphire Blue Ball with a "Retro" style?  Do you have a Clear or Frosted ball also?
Thanks for the help.
