Author Topic: How do I remove zip files from the WinXP folder view list?  (Read 1146 times)
Tiger-Heli
    • Tiger-Heli
« on: March 08, 2006, 02:45:16 pm »
See attached screenshot.  The .zip files on the left are in the AVG folder.  I just want to see the folders, not the individual files (and if I click the files it shows me the contents).
I searched for an hour on Google and couldn't find anything?
Did XP always do this?  Annoying as heck!!!
2600
Re: How do I remove zip files from the WinXP folder view list?
« Reply #1 on: March 08, 2006, 02:55:16 pm »
What the were you searching for that it took you an hour?
regsvr32 /u zipfldr.dll
Note: you may need to put the entire path in
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 08, 2006, 03:19:16 pm »
Man - this board rocks!!! Can't believe that came back in ten minutes.
I searched
"no .zip files in folder tree"
"normal .zip file WinXP Explorer"
"zip file preview in WinXP Explorer"
"don't show zip file contents in Explorer"
And probably 40 or 50 links with no good results.
THANK YOU!!!!!!!!!
Necro
  • Last login:November 29, 2022, 08:22:22 pm
  • Building a 'Classic' MAME Cab
« Reply #3 on: March 08, 2006, 04:07:22 pm »
I was just about to post 'uh...go to google' (then I saw who posted it and decided you didn't deserve the crap :) ).  I think the best thing would be 'remove zip from explorer'.  And it's on annoyances.org also. :)
rfryar
  • Last login:August 17, 2006, 02:30:38 pm
  • Currently building a custom cabinet.
« Reply #4 on: March 10, 2006, 01:16:59 pm »
Here is how to turn off the built in ZIP support and then use a real tool like WinRAR or WinZip..
How do I turn off Windows XP's built-in support for ZIP files?
http://www.annoyances.org/exec/show/article03-202
